Question about D-Link Computers & Internet
I cant seem to find driver for dlink dl10038c dfe538tx for 2000 getting frustrated 2000 dont recinize the network card and i cant get on line
  • 55 Answers
Posted on Oct 10, 2009
Internet light wont come on have checked all other connections still cant get on line
check your network card driver... whether it's a cable modem or a usb ? seems that your network card lost it;s driver or is turned off in driver properties with computer on check your network card to see if the green lights on the back are flashing? if they are they do a driver update and make sure it iis enabled in driver manager
Jan 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Setup is unable to detect card however windows
You aren't very descriptive. Either way. I'm assuming when you say Setup, you are referring to the driver installation setup. Delete/uninstall the driver. Unplug the adapter. Now, start the setup. When the installation goes along, eventually it'll ask for you to insert the card, thats when you insert it. It should then work, if you finish the setup. If thats not the issue. Heres a possibility. You are running windows Vista, or running Windows Vista 64 bit, or maybe XP 64 bit. Either way, you are likely using a 32 bit driver, on a 64 bit machine. Or vise versa. If not then you could be using a vista driver on an XP machine and the XP machine doesn't know what to do with it. I suggest going to dlinks website. There are 3 versions of this wireless card, and that also could be the issue. The first one they released is here http://support.dlink.com/products/view.asp?productid=DWL-G630 and that only has drivers for XP and 2000. http://support.dlink.com/products/view.asp?productid=DWL-G630_revB rev B. Also only XP and 2000. http://support.dlink.com/products/view.asp?productid=DWL-G630_revC rev C. also again XP and 2000 BUT includes a Vista 32 bit driver. I hope i helped. Not bad for free...
Jun 09, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
D-Link Air DWL 650 connecting to my Dlink router
You need to go into the wireless driver advanced properties and set the SSID, WEP Key, channel and others. Wherever there is an 'auto' option, choose it.
I never got the dlink utility to work. I let windows manage it and change the device settings in advanced props.
Nagu
Oct 30, 2008 | D-Link Air DWL 650 802.11b Wireless...
Keep loosing my wirless connection
Router setup page for a DLINK should be 192.168.0.1 Right click on the D and click on show available wireless networks. There maybe more than showing. If a neighbor has one or if you have another pc it might be trying to use rhe network card from that oc. Make sure that you click on DLINK for wireless connection. You just may see some other connections and find out that it's trying to use another connection.
Mar 18, 2008 | D-Link DSL-G604T Wireless Router
D-Link DWL-G550
Hi Atta,
The memory dump is not actually a error. It is the system making a log of the what is in the memory, at the time of a crash. The actual error was caused by something else. That DLink series of wireless adapter card, and thier drivers, seem to be very problematic. I found a lot of complaints, like this one, about them.
http://www.amazon.com/review/product/B00007LTBI?filterBy=addTwoStar
Any driver or device consistantly using 90% of your CPU is a bad investment. I am not a Dlink hater, since I use two Dlink routers.
You can go here, and get the most recent drivers for that adaper, and see if they help.
http://support.dlink.com/products/view.asp?productid=DWL%2DG550#
If the situation continues, and Dlink doesn't put out a fix, you might want to switch to a different brand. One other "fix" I have seen work on several problematic devices like this, is to disable the Dlink Wireless software, just keep the drivers, and use the Windows Wifi interface to control the wireless.
Good luck.
Jan 08, 2008 | D-Link DWL-G550 802.11g/b (DWLG550)...
Dfe-520tx/rtl8139
Hi Sabka, You didn?t mention which revision adaptor you had or what operating system you needed drivers for but Rev A supports Windows XP, ME, 2000 and 98; Rev B supports Win XP, 2000 and 98. Click on the link below and select the rev A or B link then download your driver(s). http://support.dlink.com/products/revision.asp Let us know how it goes and please don?t forget to rate the posting.
Jan 05, 2007 | D-Link Network Cards: DUB-E100 USB 2.0...
Using G630 but get "network cable unplugged" message
A little confusing this, it would not say 'Network cable unplugged' if windows was refering to your D-link wireless connection(It's wireless) The cable unplugged should be refering to your Wired Ethernet card, so there must be no cable connected at one or other end. You don't mention anything about what the wireless card is trying to connect to(eg Wireless modem/router or another wireless PC). Maybe your pc is getting confused as to whether you wish to connect wirelessly or wired, as it can only work through one IP Address at a time. i could be wrong, but you probably thought that they were working but only one was, you really need to explain why you are using both wired and wireless and what is connected to what, Please reply and hopefully it'll get sorted
Oct 26, 2006 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Computers & Internet Logo
937 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
