Question about Schwinn Cycling
Schwinn Airdyne chain tension adjustment
Sounds like the Schwinn Airdnye chain is rubbing against the chain guard.
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: I would like to know how to adjust the chain on my
You will need to take the guard off their are 2 drive chain once you do that you will see the adjustments. if you adjusted your bike when you were youg then this is the same
Posted on Mar 03, 2010
Testimonial: "Thanks, I'll give it a try. Appreciate the input!"
  • 990 Answers
SOURCE: Need users manual for old Schwinn Airdyne - analog model
Sheldon Brown's Bicycle glossery is a good place to start, you can google him and he may be slow on replys but he can usally steer you in the right direction.
Posted on Aug 21, 2009
Testimonial: "I emailed Sheldon Brown. Larry"
SOURCE: older schwinn airdyne manuel
figured it out
Posted on Feb 04, 2010
  • 2926 Answers
SOURCE: I have a 2004 Schwinn
The peddle should be a left hand thread that will need to be turned clockwise to remove,the allen bolt holds the pedal in place and acts like a lock to keep the pedal from rotating off.
Posted on Nov 25, 2010
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Tip
Identifying Your Schwinn Airdyne
How To Identify the Model of a Schwinn Airdyne Exercise Bike
  • We'd like to share some characteristics of the Schwinn Airdyne bikes that can be used to help you identify the model of your Airdyne bike.
What size/type fan does it have? Is it a spoke fan like a bicycle wheel or short wide blade fan?
Does your Airdyne bike have two chains or a chain and a belt?
  • AD3, AD4 bikes have two chains.
  • AD Pro/Comp and AD Evolution Pro/Comp bikes have a chain and a belt.
How do the crank arms attach to the Airdyne, by wedge pin or bolt?
  • AD3, AD4 and certain AD Pro/Comp crank arms attach by wedge pin.
  • Certain AD Pro/Comp bikes have crank arms that attach by bolt.
  • AD Evolution Pro/Comp bikes have crank arms that attach by bolt.
How To Identify the Model of Schwinn Airdyne Bike
on Mar 11, 2015 | Schwinn Original Airdyne
Squeaking belt on airdyne bike
I love my Schwinn Evo Comp AirDyne. After 2 years it suddenly developed a bad squeak and about .5" of increased play in the pedals (ie the pedal could rotate back and forth about .5" before turning the fan). Both these symptoms were caused by a broken spring in the chain tensioner. (Schwinn pn 13000371. See part 80 in blowup 5 of http://www.fitnessrepairparts.com/diagram/114 ~$9).
To replace this:
  1. disconnect the right hand (as you sit on it) connecting arm (ie the piece that connects the pedal to the big handle) from the lever arm (ie the big handle you pull back and forth) by removing the connecting bolt with an Allen head wrench and an adjustable wrench. Note the order of the three internal washers as you remove the connecting bolt. Rotate the connecting arm towards the back of the bike to get it out of the way.
  2. remove the four phillips head bolts that hold down large right hand plastic cover. With the connecting arm out of the way this cover can be pulled far enough out to gain access to the chain tensioner.
  3. remove the broken spring and replace it. I fashioned a similar spring with less tension which seems to work as a kluge. The original spring broke at the outermost loop, so I might have been able to reuse it by just bending down another loop.
  4. could lube the chain while you are in there, but you can also lube it anytime from the other side
  5. put it all back together
Jan 21, 2014 | Schwinn Airdyne Evolution Comp
ADJUSTED CHAIN BUT STILL HEARING SOUND AROUND FRONT CHAIN
I think the best solution is clean-up your chain first.
Jan 15, 2014 | Schwinn Original Airdyne
How to tighten chain on schwinn airdyne evo
if you do not have the instruction manual section troubleshooting, download for free in www.fitness.manualsonline.com or www.iconservice.com and proceed the instruction for fix it.
God bless you
Jun 16, 2012 | Schwinn Airdyne Evo Comp Upright Bike
Air dyne slips, something between the cranks and the sprocket is slipping, is there a part to tighten or does a part need replacing
Their are two sets of chain tensioners ( bracket with a bolt) and one for the fan wheel and one for the pedal sprocket and their is two drive chains depending which one needs tighten. If you have adjusted tension on road bike it is the same concept if you are unsure then a bicycle shop would and should be able to do it for you.
May 14, 2010 | Schwinn Original Airdyne
I would like to know how to adjust the chain on my Schwinn AirDyne exercise bike. There is a clanking noise when I ride and I think it is the chain hitting the guard. I don't know what model it is exactly,...
Feb 25, 2010 | Cycling
Cycling Logo
923 people viewed this question
Top Schwinn Cycling Experts
Tony
michael
michael
jasiel murphy
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
