Question about GE Refrigerators
GE PSC23MGMBCC Refrigerator Is Motherboard #WR00X2184 the right one for this fridge/ A repairman replaced if and I am having problems Also, where can I find Diagnostic codes for this appliance?
SOURCE: I have an Eaton-Viking fridge
The temperature issue will not change as you do not have a frost free fridge. With the type you currently have the older it gets the less it works. Think frost free!
Posted on Sep 23, 2008
SOURCE: GE Profile Refrigerator - Small Leak & Loud Noise
Does water come out of the water dispenser?
I is more likely that the tube that drains the water down from the self defrost mechanism is clogged. Look in the very back of the reefer cabinet, you will see a trough back there, if it is full of ice and water the drain tube is clogged up. If so, a little blast of air from a can of air (like the ones you use to blow off computer key boards will blow it out. Then the water can drain down to the evaporator pan and you will no longer get water on the floor.
Posted on Nov 10, 2008
  • 833 Answers
SOURCE: GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Posted on Dec 12, 2008
  • 531 Answers
SOURCE: Amana refrigerator too warm, freezer too cold
the damper control is not working let me tell you what to do the air that comes from the freezer block if you can get to the damper you will see it have a get rool a piece of paper between the body of damper and the get flap and have it open if the refrigerator side start cooling is the damper control i am sure about that is the damper control
Posted on Apr 01, 2009
garing
  • 998 Answers
SOURCE: GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Posted on Aug 17, 2009
The compressor of my GE PFE 29PSDASS floor model comes on for a few seconds then goes off. The lights remain on. What is wrong?
Refrigerator Repair Help ' Appliance Aid
www.applianceaid.com > ... > Refrigerator Help Section
I heard a sizzling noise inside my freezer section and it looked like something ... Myfridge makes a bang noise when it shuts off; My Frost free fridge will not run at all; Myfridge is making screeching/squeak noises; My GE SxS fridge door has ... an amp meter, each compressor is rated in running amps ( see model/serial tag ...
GE Refrigerator Repair Online Manual ' General Electric ...
www.appliancerepair.net/ge-refrigerator-repair.html
FREE ONLINE GE refrigerator repair manual - Diagnose and troubleshoot ... to know basically how the bloomin' thing works, and then get on with fixing it? ... Chapter 5: GErefrigerator problem: Refrigerator is not cold and compressor is ... Do you have somequestions that you would like to ask a professional GE repairman.
Dec 17, 2015 | GE Refrigerators
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
Both refrigerator and freezer are not cooling inside temperature rose above 47 degrees
hi there,
this is clearly a problem that needs to be fixed by a professional. Please call your local repairman to have a look at your fridge.
Jun 11, 2010 | GE GSH25JFR Side by Side Refrigerator
I own a GE Refrigerator model#GBS18HBRAWW Bottom
if you mean the freezer froze up and you replaced the defrost thermostat in the freezer,then you need to check the continuity of the defrost heater assembly located on or under the evaporator coil for continuity(completed circuit) with at least one of the leads to it disconnected,if this shows good,then you need a new defrost timer,be it an adaptive or timer type,last but not least it could be a bad connection and this circuit could be losing power and needs to be checked,but this is very rare
Jun 06, 2010 | GE GBS18HBR Bottom Freezer Refrigerator
Have a GE GSS22KGMA side by side. Fridge gets warm at the top
Hi and welcome to FixYa. I am Kelly
I am going to paste part of your text and then reply:
Your text:
Repairman came back and replaced a small round part at the top of the evaporator (resistor??) <
{ That was the termostat}
I just read that the problem could be the defrost thermostat..
He already replaced it.
I hate to say it but is sounds like your in repairman hades.
So far I see 1. a new mother board, 2. new defrost thermostat and 3. new defrost heater element. (other than wiring that is everything in the circuit)
Either one of the 3 NEW parts is bad or...there is a partially broken wire in the circuit.
Hopefully this helps you understand. ( I know it does not fix your uint)
Thanks for using FixYa.
Kelly
P.s your words again:
one would expect this to be remedied.
You got that right!
Feb 11, 2010 | Refrigerators
Freezer is cold but not fridge
there is a little trap door at rear upper corner of frig/freezer. (side by side type) Not sure where it is on others. Opens to cool refrig side closes when right temp is reached, Either link to operator is frozen or broke. Should be fixed (replaced) by repairman, easy, fast not too expensive.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Repairman stated he cannot fix refrigerator coolant leak
what you want to do is replace the coolant tubes in your fridge... i would suggest calling in another repairman and see if he says the same thing please rate my solutions... please.
Jun 30, 2009 | GE GSH22JFR Side by Side Refrigerator
Clicking noise
your repairman is correct . common problem with this GE
Mar 05, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
158 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
