Question about York Furnace Draft Inducer Blower Fasco # A224
My furnace is not kicking on. It is a York model 44CF22-B. Is there something I can check before I call a repair service in?
    Problem Solver:
  • 14 Answers
Is it a gas burner? Does it have a pilot light?
Posted on Oct 03, 2009
The modal number and serial # for my furnace is MODEL # F+RPQ24HQ6A SERIAL # EEGS13264Q OUR FURNACE IS IN A METAL BOX AND WE CANT SEE THE BRAND NAME IS WE JUST BOUGHT THIS HOUSE BACK IN DECEMBER 2016
That's an older YORK product. The serial numbers are all coded by the alphabet. York or Luxaire parts house can help you. Probably about a 1980's unit. Hope this helps!
Mar 18, 2017 | Heating & Cooling
Gas central heater
The "mother board" or integrated control module is essentially the brain that controls the sequence of operation in your gas fired furnace. It is located, generally, in the blower compartment. That is the bottom of the two compartments of the in the furnace. It looks like a circuit board with all the wires of the furnace leading to it.
Feb 28, 2014 | York Furnace Draft Inducer Blower Fasco #...
York furnace model p2mpd12h06401f flashes 4 times for trouble code does'nt have code list inductor motor comes on but ignitor does'nt come on
Check pressure switch for inducer motor. If switch closes, check for crack in ignitor. If gas valve opens and you can hear/smell gas, the ignitor is bad probably. If pressure switch isn't closed you need to check for blocked vent/chimney/heatexchangers.
Dec 18, 2009 | York Furnace Draft Inducer Blower Fasco #...
Blower and ignitor work and then kick off but will work again after shutting furnace off for a while and turning it back on. This problem seems to occur when it is colder outside rather than above 30...
I had the identical problem with my York. Problem was the burners. The heating element would light the first burner but the flame wouldn't move to the other burners. The flame sensor didn't detect a flame on the last burner so the gas valve would shut off. I removed and cleaned the burners then reversed the first and last.
Dec 05, 2009 | York Furnace Draft Inducer Blower Fasco #...
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Problems with Furnace
On is just the blower fan nothing else, check to see if there is a reset button in the tstat or tripped over load inside the furnace, inside the furance is some safetys, you will see wires runing from each other and finaly to the gas valve, push each untill one of them clicks,then your furnace should start back working, but I would still have someone come out and check why it tripped, because as I said it is a safety, and when it tripps it is for a reason.
Oct 19, 2008 | Heating & Cooling
York  Furnace Draft Inducer Blower Fasco # A224 Logo
1,291 people viewed this question
Top York Tools & Hardware - Others Experts
vince
Paul Carew
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
