Question about Refrigerators
Model #PSC23MGMBCC A repairman replaced the mother board and I have had problems ever since Is part # WR00X2184 the right one?
  • mkemk5 Oct 05, 2009
    Thanks for the response.
    I have no idea if he programmed it at all, let alone correctly. Based on the repairs the 4 or 5 Sears "technicians" made I doubt it. One of them actually said that the thermister near the bottom of the refrigerator was a vent and the reason why food was freezing in the drawers was because we had the vent blocked. How ould I go about checking if it was programmed?
    Thanks again
  • milten1
    milten1 May 11, 2010
    yes but i wonder if he programmed it correctly
3 Suggested Answers
jeffbvegas1
  • 520 Answers
SOURCE: same problem
These are both very popular and fast moving items on parts counters everywhere. Unfortunatley it is not un-common for both to be problematic.Installing the ice maker is fairly simple procedure and you can save half your hard earned at least on that.I am noticing new and seemingly improved relays on these boards so hopefully it will last like it should.Ice maker is another story. One might consider purchasing an extended warranty for todays "new" fridge and they are all about the same
Posted on Jul 11, 2009
  • 1218 Answers
SOURCE: Mother Board
Laura,
You win. Most GE side by side refrigerators have an electronic mother board.
Data is feed to it from 5 thermistors, 2 in the freezer and 3 in the fresh food compartment.
In turn the motherboard takes that varying information from the thermistors and controls all functions in the machine.
Posted on Apr 06, 2010
Testimonial: "Thank you!!!!"
I have a kitchen aid, 8 year old, 42" built in model #KSS042QTX that is not working. Repairman says it is computer mother board and unable to find a replacement as we cannot find serial number..Help?
Usually it is located on the back of an appliance on a silver metal strip.
For Assistance for Major Appliances call 1-800-422-1230.
For Counter Top Appliances 1-800-541-6390.
Jun 10, 2017 | Refrigerators
My tablet klu by Curtis model # LT7035-L will not power on
I have similar problem. when charger connected, Isee ared light indicating charging function ok. A repairman checked it and am told mother board not functioning. Try getting it checked if someone can do it for free and suggest repair. GL Marsha.
Nov 19, 2014 | Tablets & eReaders
I HAVE A KITCHEN AID MODEL NUMBER KSRA25FKSS00 and it is not cooling
have you replaced the ptc overload/relay on the compressor,as this is the actual start and run component that the compressor needs or it wont start or run,remove it by unplugging it off the compressor and a good sign if its bad is it will sound loose like pieces loose inside the ptc unit,you should also replace the run capacitor connected to this component too
Nov 29, 2012 | Refrigerators
Tv clixs on and off
check the capacitors and replace the power components.. if not handy with soldering electronics call Tv repairman as you may need to replace capacitors and possibly mother board .. Tv repairman may charge 75-150 dollars depending on cost of Mother board .. good luck
Sep 21, 2012 | Sanyo 42 in. LCD TV
Ge refrigerator model # RG2300NGSBRO does not work. I suspect it is the mother board that need replace
yes, if the refrigerator is not working at all then its the main motor's problem. this is a big problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Mother Board
Laura,
Apr 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Same problem
Icemaker is pretty much independent from the mother board, but you don't say why you replaced the mother board, or why you think you need to replace the icemaker (problem with it is?). If you need to replace the icemaker, you can do it yourself rather easily and should save a good chunk of money by doing it yourself.
Jul 09, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Yahoo games
Hi yoyo209:
You may have a failing mother board. This is a common problem with these models...do some search on the web.
Best maybe to replace the mother board with a same size board. You may have to re-install windows over your system to get the drivers and mother board to work right.
Oct 17, 2008 | E-Machines -T1840-CELERON-1.8GHz,40GB...
Power shut down
Then let the repairman do the work. As long as he has a replacement motherboard and he can make your PC like new and work again. But think about the price if it is too high that you can buy a new one. Much better to have a new one right?
Apr 13, 2008 | HP Compaq Presario V5000Z Notebook
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
