Question about Garden
My push mower makes a revving noise after its running for a few minutes. whats the problem?
    President:
  • 986 Answers
You going to think Im crazy but just replace your air cleaner.If Im wrong just call me crazy,mine did it it would rev back and forth and the bottom of the air cleaner was plugged I cleaned it and it was just fine,I hope this helps you
Posted on Oct 03, 2009
How can I bleed lines?
set the rear of the tractor up on a block so the back wheels can spin freely. Start the tractor and run it through reverse for a few minute then forward for a few minute . That should move enough oil to get it out. Make sure it is engaged before . If it is engaged it should skid the wheels if you push it.
Mar 18, 2016 | Garden
Riding mower revved up and now wont start
I am wondering if you have a broken spring on the carburetor. There are springs that hook the linkage up to the lever you use to speed the engine up, Also on the carburetor its self. If a spring is broken the engine may rev out of control and yes it has to be repaired to start don't try to run before repairing or you will blow it up.
Mar 30, 2015 | Garden
Masport 4 stroke mower...started it up and it worked for a couple minutes with a strange rattling growling noise.. Oil ok and petrol filled but the mower just shut it's self down and im not sure w
It will run for a few minutes and then shut down?
Lets ignore the growl for now. Loosen Gas cap and see if it will keep running. The rattle might be in the pull cord mechanism..possibly not related to stalling issue
Dec 03, 2012 | Garden
What would cause the lawn mower to stop running when not out of gas? If you give it a few seconds and restart it it will run again for awhile then stops. I have noticed if I pump the primer a couple of...
Try using non-ethanol gas. It's death on small engines. Starter fluid gives it a boost if higher octane. Have a reputable repair place clean out the gunk, then use good gas. Best of luck finding non-ethanol. Boating marinas carry it.
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Revving noise in central air unit
are you sure the revving sound isnt a loose grill around the condenser or something setting up an on-off revvind sound-vibration by the speed of the unit,go out to unit and push and prod on exterior of unit and look down inside to see if anything could be loose
Sep 23, 2009 | Heating & Cooling
Poulan lawn mower, Briggs Stratton engine, revving problem
Most likely problem is dirt?moisture in the carburetor float bowl. You would have to remove the bowl, clean it out and also clean the main jet up in the center of the carburetor. Another problem could be that the governor is out of adjustment but this is not something a novice could or should do
Sep 12, 2009 | Poulan "Poulan" Push Mower
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
My mtd tradesman lawn mower does not run smooth. where is the idle mixture adj. screw? the engine is the tecumseh 5.5 hp model #VLV55 501029A(D)
The newer machines do not have a way for you to adjust the Idle, what you can do is change the spark plug or spray some carb cleaner or remove the air filter and run it for a few minutes without the air filter and see what happens
Apr 14, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
