Question about Exercise & Fitness
I have a powertrek treadmill and at the moment it constantly beeps and an error message appears saying ER07, can anyone help me with this error
4 Suggested Answers
  • 103 Answers
SOURCE: Proform 8.5 ifit treadmill will not start. Power
Hello There, Unfortunately the sound are hearing is caused by a stuck button on your console assembly. When this happens you will be unable to select any buttons due to this condition.
The only fix is to replace the console assembly.
If you go to iconservice.com you can get parts and pricing information.
Get your model number before going there. Should be (PFTL788072) and is located under the walk belt on the lower frame assembly.
Good Luck! Tim
Posted on Dec 21, 2009
georgiejm201
  • 54 Answers
SOURCE: my powertrek treadmill when switched
Typically when this occurs, it is an indication of a short circuit in the motor controller. Please follow the following steps to solve the problem:
First Test
1)Unplug the treadmill from the wall.
2)Remove the motor hood.
3)Unplug the speed wires from the controller. On many controllers, you will have 2 to 3 wires that control speed and many are labeled H, W, and L. If you cannot find the speed wires, do not guess, contact us with your make and model number and we will try to help you with the wiring.
4)Return the treadmill to a usable position once the speed wires are disconnected and plug the treadmill back in.
5)If the treadmill begins to run at full speed, the motor control has failed and requires replacement.
6)If the treadmill does not run at full speed you could have a speed input problem, wiring problem, or another short circuit.
Second Test
1)Unplug your treadmill from the wall.
3)Check and see if your controller has three speed wires labeled H, W, and L or a unified wiring harness labeled H, W, and L from the console. If not, you have a digital controller and full speed upon power up is always a failed controller. No need for further testing...you need to replace the controller.
Posted on Jan 11, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a lifegear motorized treadmill. After using
1)Alternative: Elevation Out Of Range
2)tsu3fngh4aaaaasuvork5cyii=
Posted on Nov 03, 2011
I purchased a Manual Powertrek treadmill possibly approx 5yrs ago,lost the manual and there is no part number on the treadmill,how do i contact Powertrek direct,thankyou
go google and type in ---powertrek-- find their page that has a "contact us" section click on that and there should be an address, phone number, fax number and e-mail address.
Nov 07, 2016 | Health & Beauty
Er07 appears on screen on the health trainer treadmill. Remedy?
Error Er07 is usually caused by a bad button on the console of the treadmill. Go to this site to get help to resolve the problem.
https://www.iconservice.com/
Jan 07, 2015 | Exercise & Fitness
Domyos Tradmill just Bleeps when turned on
adjust the REED switch, see the diagram attached. Clean it+test for open or faulty +tight the connector very well.
Jun 09, 2013 | Exercise & Fitness
I have powertrek treadmill and the powerlight on the rear switch is on but no display power or reset button. There is a fuse next to powerswitch that says f12al250v. What amp would that be??
1) see the block diagram attached and proceed.
2) Adjust the REED switch, clean it, and tight the wires connector v. well.+tight the ribbon cables, tight the wires connector v. well. vs lower board wires connector
God bless you
Jul 10, 2012 | Exercise & Fitness
Powertrek treadmill jerks to start and straight away to stop repeatedly. what can be a problem?
1) ;LUBE THE DECK BELT very well, this a sign for a deck worn.
2) lube the rollers bearings too.
3) Measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram
Good Bless you
Jul 03, 2012 | Exercise & Fitness
Lifetrack OMA-117 treadmill constant beeping not moving
1) adjust the REED swithc , see the diagram clean , and tight the wires connector very well.
2)Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 29, 2012 | Exercise & Fitness
How do i tighten and centre the belt on POWERTREK
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 13, 2010 | Exercise & Fitness
Exercise & Fitness Logo
190 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
