Question about Garden
Just buzzes when I turn the key - Garden
  • Chuck
    Chuck May 11, 2010
    IN
    MOST CASES, A BRAND, MODEL NUMBER, SERIAL NUMBER AND ENGINE
    NUMBER/BRAND IS NEEDED TO OFFER ADVICE AND/OR HELP.
    Without
    them, we have no way of determining what you are trying to
    repair/troubleshoot to give you the best answer possible for your
    problem.
    Scholar:
  • 110 Answers
Either the battery is flat, faulty, or there is a loose connection somewhere in the starter circuit. Ususlly, its the engne ground cable (if fitted), or the battery ground cable.
Posted on Oct 04, 2009
I have a1995 2.0 non turbo Talon. New fuel pump relay and a new ASD relay . it cranks but fuel pump doesnt prime or come on and there is no spark. is there a shut down reset ? Do I need a reflash on my...
the autoshutoff relay may be out also..it controls both the ignition and fuel pump thru the key switch.. try taking the negative battery cable off with the key on...kills all the circuits..then after turning the key off..reconnect the cable and turn the key to the run position..DO NOT START..listen for the fuel pump to buzz 2-3 seconds..some dash indicators will go out..then try to start but only if you hear the pump buzz..if it does not buzz, be looking at that relay..
Dec 18, 2013 | 1995 Eagle Talon
Loud Buzzing when turning key
Something is froze up. Try rotating the engine "key off" to see if it is jammed. Then remove engine cover to access the starter motor.
It should spin freely. If there is no apparent problem remove the flywheel and inspect the shaft key and magneto settings. If you need more repost.
May 05, 2013 | Garden
I didn't turn the key all the way when I went to start it,now it will not start. It makes a buzzing noise
try rocking the car back and forwards and try it again you may have jamed it
Mar 26, 2012 | Audi A4 Cars & Trucks
Engine will turn over but will not ignite
see if you have spark at the plugs , start there, try this also ....turn key to on position listen for buzz at fuel tank, if no buzz it needs a fuel pump.
Mar 16, 2011 | 1997 Chevrolet Blazer
Y my 1999 yukon dont turn on. it crank but thats it
Fuel Pump:
Have someone listen at the fuel cap for an audible buzz when ignition key is turned on.
if no buzz no fuel pump need new one..
Nov 22, 2010 | 1999 GMC Yukon
Let's see if there is really a diagnostic expert out there for this... 1996 Plymouth Voyager 3.3L engine with 165,000 miles. I'm having intermittent starting problems. I can drive for weeks and no...
The way to approach this sreies of issues is to first remove the remote start/alarm from the equation and restore the vans electrical system back to original. From there, if it persists, we can do more trouble shooting. Let me know and I can walk you through the process. This is definately a problem that does require a diagnostician. Thank you for the level of detail you provided!
Mar 19, 2010 | 1996 Plymouth Voyager
ELECTRICAL PROBLEM, KEY STUCK, FUSES BUZZING
The fuses that are buzzing, are these the ones you replaced? Sounds like a bad connection to the fuse panel, but the ones you removed are they fuses or relays. Did you have to repair any wiring or plugs for the window? Check the connection at the main window panel, if it has a bad connection such as not plugged in completely.
Jan 17, 2010 | 2001 Pontiac Aztek
Buzzes all the time
You were in the middle of some kind of operation. finish what you were doing and it should be fixed.
It also helps when you mention what model of TEC cash register you are using
Sep 16, 2009 | Casio Parts Cash Register PC Desktop
99 Dodge Neon sohc. Drove to work just fine came
How old is the battery? Clean the connections, charge the battery. Try starting it. Get the battery tested at Autozone or some place like that.
Jul 03, 2009 | 2002 Dodge Neon
1992 cabriolet will not idle
The ISV (Idle Stablizer Valve) could be clogged or just not working. It's a cylinder with 2 vacuum lines and electrical connector going to it. Just above the valve cover and below the intake manifold. Best check for that is turn the key on engine off and the ISV should buzz. If it is buzzing remove it and clean it with some throttle body cleaner or brake clean. Reinstall and check for idle concerns. Have to be quick to see if it buzzes though. Better to have someone turn the key for ya while you check the valve. If it doesnt buzz replace it. Also check the switched on the throttle body. See if any of the wires are broken.
May 27, 2009 | 1992 Volkswagen Cabriolet
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
