Question about KitchenAid K45SS Classic Stand Mixer
Does this machine ever need grease or oil? - KitchenAid K45SS Classic Stand Mixer
    Sergeant:
  • 233 Answers
No! Typically these are permanently lubricated at the factory.
Unless an expert that does repair work on this type of machine comes in and says something different. I would avoid opening this machine up and adding any kind of grease or oil. It may wind up in your next cake! :)
Posted on Oct 05, 2009
Testimonial: "Thanks very much. There are sites on the web that show step-by-step re-greasing of these machines but nowhere does it say it is actually needed."
Leaking oil
To remove the planetary you knock the silver pin out with a punch. There is no 'oil' as such in the machine. Sure it is oil but it is breaking down out of the grease. It is harmless and food grade so nothing to worry about. The grease should not have got to the point it needs replacing until it is about 5 years old. I would remove the planetary and wipe the shaft clean and any excess inside the planetary remembering that you do need to leave some lubrication on the gear teeth in there.
Jun 12, 2014 | KitchenAid ProLine 600 Stand Mixer
I have moved not to long ago and are kitchen aid mixer was in a box and laying on its side and there was oil all over the inside the box was soaked in oil . how do i check the oil level and what type of...
Wipe the oil up and use it. The machine has no oil in it, the grease is degrading and the oil is coming from there. It will be fine, next time it needs work done on it have them change the grease in the gearbox.
Dec 07, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
There is oil dripping down into the bown from the mixer.
Oil dripping from the mixer indicates that the grease in thegearbox has turned to oil. In that case it needs servicing. It needs to be sentin for re-greasing. Gear breakingcould be another cause, but if your machine working correctly then you cansolve this problem by simply re-greasing it. Hope this will help you. Good Luck.
Aug 06, 2011 | KitchenAid Food Mixers
OIL IS LEAKING OUT OF THE HEAD INTO FOOD BOWL. KITCHENAID SAID OK, FOOD GRADE OIL! I DON'T LIKE BLACK OILY CAKE OR COOKIES? CAN YOU HELP US TO FIX OURSELVES.
Kitchenaid says to run the machine on 'high' long enough to heat the gearbox well and then turn the machine upside down and let it cool.
What happens is when you don't use your mixer a lot the grease in the gearbox will separate into oil and thicker grease. Warming it and turning it upside down is supposed to mix all the grease together again and allow it to flow to the top of the gearbox.
Give it a try, check back if you get no satisfaction and we'll get you started on changing your grease.
lp
Jan 01, 2011 | KitchenAid KSM103 Professional 5 Series...
I have model A-200-D Hobart mixer. Serial # 1575984. It is leaking oil into the bowl. Who can I call to get an estimate to service or repair this machine?
The oil leeking into your bowl is old grease that has broken down into oil and is getting past your oil seal you need to take out all of your old grease and oil replace it with hi-temp grease or a good grade lithium grease and replace your agitor shaft oil seal
May 16, 2010 | Food Mixers
Leaked oil
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
Apr 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Mar 19, 2009 | Hobart HL200C Mixer
Oil leak on A200
OK guys, let's try to solve your common problems first then the rest will become clearer.
The Hobart A200,,,,,,,, does not use oil! It uses grease! If you see oil, it's because the grease is separating the oil in the grease. Both machines have not been serviced for at least 5 years. That's about the lenghth of the lifetime of most greases. I recommend that you call Hobart and ask about their tech. rates. All bearings should be checked carefully for wear, as should the worm gear, seal, and the Bronze gear that it turns. The Planetary (mixing part), should be removed as well, cleaned. and inspected. Replace the seal on the planetary and on the mainshaft. Removal of all old grease is required, as it's no longer doing the job it was designed to do, will result in advanced wear, and is the actual source of your problems. The seals were designed to seal grease, not oil.
If Hobart is too pricey for you, and they are for many, try to find someone from a wholesale restaurant equip. place who has rebuilt these machines, or find a repair shop who have experience with this Hobart model. If you'd like to tackle the job yourselves, go to www.hobartservice.com. Register for free, then find the files that match your mixer model and ML # and download the parts files for it. These exploded drawings will be very helpful with your task.
Either way, these mixers need to be opened up to remove existing oil and hardened grease, especially the oil! The planetary must be removed to drain any oil out of it and to regrease it. If you can get the oil out of the mixer, a short fix would then be to simply regrease the the mixer and put it back into service, leaving the existing seals in place. Don't forget to wipe out the shiny ring on the planetary, if it too has oil in it.
There is no seal at the hub. No seals can be tightened. The oil leak underneath the mixer comes from the motor shaft seal at the transmission case where the pinion gear enters the trans., it flows down into the mixer support column and drips onto the floor or counter, again, because of the breakdown of the grease.
If you tackle the job yourself, find your local Chevron Distributor and get several tubes of the approved grease, namely, Chevron FM ALC EP NNGI 2. Chevron p/n 230204-000. If you've found this solution helpful, please rate it as fixya!
Good Luck! ricardok45
Jan 19, 2009 | Hobart A200 Stand Mixer
Kitchenaid stand mixer oil leak
Hi. The grease that your mixers are lubricated with has reached a stage where the oil is leaching away from the grease. All your machines need this grease changed. Shell Darina EP-2 or Chevron FM ALC EP-2. These machines need to be internally cleaned and re-greased. It's important to remove the oil from any place that it drips. The planetary gear must be removed, cleaned and re-greased also. It's a messy job, but you can do it yourself if you're familiar enough with machinery. If not, then a suitable service outlet can easily do it.
If you choose to do it, go to the Kitchenaid website and locate the parts files for your particular model, these drawings will assist greatly with the project. If you can, take digital photos at every step of dis-assembly as a reference for re-assembly. If this solution assists you, please rate it. Good luck! ricardok45
Dec 31, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Hobart h400
Greg,email the pics--there is a oil/grease flinger that can be installed if the model is right.I need the serial #,ml #.
Jun 03, 2008 | Hobart A200 Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
281 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
