The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly. However you can try adjusting the spark gap to see if this will resolve the issue. Heat will often expand the spark gap thus rendering a spark impossible. Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery. Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Was this helpful?
Yes
No
Popular Solutions for Weber Genesis Silver C Grill
