Washing Machine problem
My top loading washing machine is filling with water and then making sounds like its trying to go but doing nothing. It almost sounds like the agitater (name?) doesnt have the power to move. Its still full of water. Any thought on how to fix or expenses involved? Should I check something before calling a repairman?
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Couldd be motor or belt..loose, ifits motor possible that motor brush kit is worn epect after about 4 years, if this is case can be fixed not too expesive if motor may need new machine.
Posted on Oct 03, 2009
Sm8280867
See if all the connections are tight; try inter-changing the water pipes. Water should have good pressure at faucet.......
Apr 27, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
My washer was filled with water but wont spin.. makes little noise but no spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 18, 2011 | Maytag PAV5157A Top Load Washer
Turn washer on, only get a buzzing sound. No water fill, rotation of agitator, nothing
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Nov 26, 2010 | Whirlpool LSQ9600L Top Load Washer
Wont fill with water
Here is a tip that I wrote about no water coming into the washing machine2_bing.gif...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Washing machine quits after filling
I believe you need a new belt. The weight of the water is to much for a loose belt that is connected to the agitator.
2. Make sure nothing is blocking the safety shut off located on the machine.
Jan 19, 2009 | Washing Machines
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Roper top load washing machine
you may have a bad lid switch,or the lid is not making contact withthe switch . not recognizing the door being down the machine , for safeety reasons, will not advance any furhter
Nov 02, 2008 | Roper RAX4232KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
