Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Dimension 5150 fails to turn on when i press the main power button. It makes a jarring noise about five times and then nothing, no connection with the monitor, no activity. Any ideas?
    Sergeant:
    Novelist:
  • 191 Answers
My first inclination would be to check the power supply. There is a fan within it. If it is not turning and pushing out air, the supply will immediately fail when it gets hot. Upon starting PC, you should hear that fan and feel air coming from the vent holes. I would also check to see that any case fans inside are clear of cables. Hard drives and other media drives could also make the sound, but they shouldn't prevent PC from starting.
Posted on Oct 03, 2009
I'm looking for advice on how to reboot a dell dimension 5150
You can reboot by Operating system , Click start>Restart
OR
you can press power button for few seconds, it will power off, & then you can press power button.It will start booting up...
Thanks for choosing Fixya
Mar 16, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My Dell Desktop Dimension 5150 does not start sometimes
loose connect or mother board problem (is your os & HDD is OK ?)
Jun 24, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My DELL Dimension 5150 fan is making a great noise, how can I fix it?
Turn the computer off.
Disconnect the AC power.
Remove the side-panel.
Buy a can of compressed-air, and give your computer a "blow-job" to remove dust from "everywhere", including the fan(s).
If you still get noise, then it's time to replace the fan.
Take the computer to any computer-store, so that they can sell you a new fan that matches the current fan.
May 07, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hi is the Power supply on a 2006 Dimension 5150
What makes you think you have a dead power supply? I would look at the connectors and see if there are 20 or 24 going into the Motherboard main connector. Then look for a 4 pin connector plugging in near the CPU. If it looks like the mounting holes line up, you have a winner. Most are interchangeable anyhow. Try to get some SATA connections on your new one.
Dec 19, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Noise from unknown source
Grrrrrrr - Could be CD running, Could be Fan on the CPU, which if not fixed will kill you main chip, could be power supply fan, check in the back and see if fan is turning consistanly ( I think that is how you spell that) If you know how to remove covers, take side off and look at fan on the CPU or other fans and when you hear the Grrrrrrr se if you can tell where it is comong fro, also some hard drives will make a sound as they get older.. Good luck....
Apr 23, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Start up fault
I'm not an expert at this!!
I looked up Dell Tech Faults on another pc.
Disconnect power and press on button to discharge pc. Remove side panel. Remove all USB port cables including hubs. Remove memory from the CRIMMS. Reconnect memory. Reconnect usb's. Replace panel and power cord. You can always connect to Delle Tech Support - doesn't cost.
For some reason only known to anoraks or rocket scientists--- this works and pc is restored to former glory.
Hope this works for you too.
rgds
Stuart C
Dec 13, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
449 people viewed this question
Alun Cox
