Question about Dryers
The heat is working but the drum doesn't turn
    Genius:
  • 1,466 Answers
Check broken belt 1st
Posted on Oct 03, 2009
Barrel isn't turning.
I believe you will find the belt is broken.
There is a motor which is supposed to turn a belt, which in turn drives the drum.
If you wish to repair ir yourself, a letter to "Fixya" could cause someone to walk you through the steps.
Be blessed.
Mar 04, 2013 | Frigidaire FGR641FS Gas Dryer, White, 5.7...
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My dryer will heat but won't turn, I replaced the Dryer motor but it still doesn't turn. The door switch works fine, when I push the start button it clicks like normal and when I open the door I...
Have you looked for a belt on the drum of the dryer? Mine has a motor but it is attached to a wheel that turns large belt that extends around the drum.
Oct 03, 2017 | Roper Dryers
My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
Sep 22, 2011 | Dryers
Drum doesn't turn..Motor sounds fine and dryer sends heat. Drum turns freely when moved by hand.
replace the belt and idler pulley as a set sold at any Sears store
Aug 14, 2011 | Dryers
Recently moved to new house. Dryer was working before, now it runs, drum turns but doesn't heat. Have tried adjusting fabric setting. Outside vent is clear and blows while running.
more than likely the heating element is not working. if there's no heat at all, this is probably the culprit. you have to gain access to the heating element to test it for continuity. no continuity=bad element=needs to be replaced. if you can get this far, then it's easy to change it out.
Jul 06, 2011 | Amana DLE330RAW Electric Dryer
Dryers Logo
Top Dryers Experts
