I have a toshiba 75H94 tv and it did not power on. the green light is on but no picture or sound
  • 4 more comments
  • Mhammed Elkhalfy Oct 03, 2009
    The TV model is 57H94. It is a Toshiba. I cheked the board, and I did not find any blowing capacitor. The fan is working next to video card. Do you any any thing I can test the voltage or ...? Thanks
    The website did not allow me to download Service Manual?. Do you have a service manual by chance. Thanks
  • Mhammed Elkhalfy Oct 04, 2009
    the download botton did not show up. It just shows "Plaise wait". I waited for more than 40 min, no thing happend. Can you email me the file. Thanks
  • Mhammed Elkhalfy Oct 08, 2009
    I have a Toshiba model 57H94 with no power, picture or sound, but the green led is on in the front. The fan in the back is on. I just need step by step to change or test any components of the circuit. Thanks
    I have a Toshiba Model 57H94 the green led is on but no power, picture or sound. The back fan is working. Any help, thanks
    Do you have an schematic or step by step solution to this problem. What is the most abvious defect in this unit?. thanks
  • 395 Answers
Press and hold the "Menu and Volume key <" this would reset your tv. If this did not work then maybe you should replace a probable blown power supply. most likely caused by defectiveelectrolytic capacitors that if are electronically handy can bereplaced for a few dollars.
Here is a link to some one who experienced what you are going through and how he got his repaired for less than $30.
http://recycledpapyr.us/2009/03/26/blown-power-supply-on-philips-plasma/
Defectiveelectrolytic capacitors from China are a rampant problem. Cheap Dell,computers fail all the time because of this problem.
Good Luck
Posted on Oct 08, 2009
  • 3,866 Answers
The first thing to check is the power supply on this unit. Make sure there is not bad capacitors,relays,fet, etc, etc
Also there are things to check like the lamp inside and what not. Get back to me if you have more questions.
I would have this repaired as this is a good TV..
Please click the accept button if you like my advice, Thanks
  • 11,896 Answers
Check the powe comin from the power supply eading to your main control board. Itshould be about 12-13.5 volts. Anything to high or too low would indicate a fualty power supply which is failry common now days. You can also test other capacitors and resistors with an ohmmeter or capacitor tester to find the faulty one. You can get parts and manual at shopjimmy.com
  • 19,396 Answers
I did not find the model, I think you are referring to a rear projection TV.
The TV is on protect mode, a special fault mode, that will keep the TV in standby, shutting down higher voltages from PSU.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board. When it is the lamp depleted you usually you get a faulty lamp code explained on owner manual.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Regards.
Posted on Oct 03, 2009
Toshiba regza tv switches on but has no picture or sound
I can try to help but: what is the model number and how old is this set? Model and date made will be on rear of set.
Dec 19, 2012 | Toshiba Televison & Video
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba 42" plasma tv 42HP66. All of a sudden, no picture.
Hello, You may have a bad power supply! Its hard to say! I need more info! please feel free to call or message me if you would like more help with your TV!
Thank you!
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Apr 07, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba HD TV Model # 42HL117
Toshibas are notorius for Sustain board failure, You will have to find qualified servicer thru craigslist or yellowbook. If this is your problem, you could see a repair bill of 400+
Craig Cleveland Classic TV www.classtorations.com
Jun 08, 2008 | Toshiba Televison & Video
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
