Question about Rival CZF530 Deep Fryer
Power light does not come on and does not heat the oil.
I looked for a reset button on the back of the control panel but see nothing that could be this button. I have contacted rival and am waiting for their reply.
    Genius:
  • 1,474 Answers
Check your plug fuse is ok 1st, reset could be thermal automatic..wait a wee while 1st
Posted on Oct 03, 2009
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
My kenmore dishwasher 665.17052400 clean light is flashing 7 times. I cannot locate the tech sheet to find out what is wrong. I have reset the panel and it will run then blink again after 15 mins or so. ...
Reset the Control Panel
A power surge or outage may cause the "Clean" light to flash continuously after power is restored. Pressing the buttons on the panel in order and within 5 seconds resets the control panel and turns off the flashing light. The buttons must be pressed in the following order: "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash." After pressing the buttons, your Kenmore dishwasher will begin a short, 12 minute test cycle and reset the control panel.
Door Switch
A broken door switch can keep a Kenmore dishwasher from operating correctly, resulting in a flashing "Clean" light. Testing the door switch requires removing the door panel to access the control panel holding the switch in place. A continuity tester can determine if the switch has failed once you remove it from the door. Replace the switch if it fails to pass the continuity test. Make sure to disconnect the electricity to the dishwasher before accessing the switch.
I hope this helps.
Jan 10, 2018 | Kenmore Dishwashers
Wont turn on is thier a reset button
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Try turning off the switch for a longer period of time - 10-15 minutes. This may reset your washer.
* If any of your button lights come on but a regular cycle will not start, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If your buttons do not light up or normal function still does not resume after the reset, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is power getting into the machine and that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to the possibility of a control (button) panel issue and you may try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Hopefully some of that helps!
Jul 02, 2012 | Maytag Dishwasher
Dishwasher control panel unresponsive
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
Dishwasher would not come on... the general cycle light is on but when is press the start button, the dishwasher would not start. i tried restting by switching off the power and then back on... same...
Hi
Yes you are right, first make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 20, 2011 | GE PDW8280NSS Stainless Steel Dishwasher
I have a whirlpool gold quiet partner III. The cancel drain button works but nothing else. If you press any of the button for a period of time the normal button flashes; nothing happens though. Any...
Try to reset the dishwasher by using this sequence of keys within 6-8 secs.
HiTemp/ heat Dry/ Hi Temp/ heat Dry/ Hi Temp / Heat dry.
If it works all lights should turn on. Press Cancel to exit.
I am assuming you have already tried to turn the mains power off and back on.
If still no difference, then the controller or the panel has packed up.
You can locate the parts from this site.
Mar 21, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Hi. My Bosch WTL 5500 wont start. It has power and filters are clean. When you push start the dry light comes on and nothing happens. Any ideas?
there is a thermal reset button at the back of the unit on the heating element. to get to it you have to remove the back panel that covers the heating element. (its the panel that sticks out). Once that panel is removed you will see the red thermal reset button. press it so it clicks, then start unit. Let me know what happens.
Mar 18, 2011 | Dryers
Heat was working until 2 days ago. When i turn on heat nothing happens not even the fan turns on. I have a bryant cant find the model type. There is aslo a blinking red light
Hello
First check that the main circut breaker is not blown.
Next be sure you have gas or fuel oil going to the heater.
On some units there is a reset button located in the furnace control panel or a small low voltage fuse could be blown.
If a reset button is there push it in.Check your documentation as to what would cause this to happen.
Jan 22, 2010 | Honeywell Programmable Thermostat Heater
GE dishwasher won't start
You have a washer control board problem or a burnt connector or both.
Mar 17, 2017 | GE 24 in. Profile PDW9200J Built-in...
Vulcan ducted heating not working
How many wires for the thermostat do you have? If you tell me I can help. The green flashing, instead of red, in my experience, means a thermostat problem.
Feb 24, 2008 | Heating & Cooling
Rival CZF530 Deep Fryer Logo
314 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
