Question about Plantronics (45647-04) for S10, T10, T20 Consumer Headset
Telephone line RJ11 jack does not fit into plantronics
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
The correct connection size for headsets used with S10, T10 & T20 is an RJ9. The jack on the back of the T10 and T20 is an RJ9, this is for the cord that runs into the wall jack. The cord itself has an RJ9 on the end that plugs into the T10 & T20 and an RJ11 connection on the other end that plugs into the wall jack. This cord is supplied with the units.
Good luck from Headsets Direct!
Posted on Dec 27, 2011
I cannot set up my answering machine on this model. Why
Hello Glenys Fisher,
No mind readers here...
(include MAKE & MODEL... pretty please).
ELSE... you get GENERIC answers
No idea if you are talking about Plain Old Telephone Service
(POTS)... or digital interface...
Even if "digital" f it has a RJ11 (phone jack)
should run an old style (central office powered phone
(the kind you want/need in an EMERGENCY)).
Only the center two wires (tip & ring (typically Green & Red))
are required. Key is always... Red = Right = RING.
If you are buying Off-The-Shelf (two wire) RJ11
phone cords the plugs are already properly oriented.
Line comes from the phone company (plugs directly
into answering machine)... Tel jack can go to a telephone
OR NOT.
All wiring is in PARALLEL.
If ANY phone is OFF-HOOK (in use) the recorder
will not work.
Is this helping...??
Carnac the Magnificent
Oct 18, 2017 | Lands Phones
RCA visys dect 6.0 Line 2's light is lit and no dial tone. All handset are in off mode. Only Line 1 is available
Are the phone cables correctly connected to the base unit? Try a new cable for Line 2, if you have separate L1 and L2 jacks. (If the lines are integrated in one jack, make sure to use a 4-conductor RJ11 cord.) I assume the service hasn't been cancelled for line 2 and that you are at a wall plate with both lines.
If you have separate jacks, I like to use a different phone to check the jack. (A simple old fashioned corded, single-line phone is useful to check for a dial tone.) Try checking Line 2 at another jack, if you have one.
If you do not have a dial tone, find where your service comes in. Open the box and look at the terminals. If you are lucky, you have an RJ11 port. Plug in your test phone in to the Line 2 connection and listen for a dial tone. If there is no dial tone, contact your telephone company. They will fix an outside line problem for free. (Mice and other things can damage the wiring. A lightning strike could damage a filter if you use the line for a high-speed internet connection.) If the terminal doesn't have an RJ-11 plug option, you will need to ask your telephone company to test the line.
If you recently had work done on the phone line, check for any wires that are loose. When we got our phone line upgraded to fiber optics, one of the telephone jack lines didn't get connected to the terminal in the new box. We found the wire behind the vinyl siding and got signal as soon as the wire was reconnected.)
If you have a dial tone at the box and no wires are obviously disconnected, you'll need to trace the wires inside to find a broken connection. If one jack worked for Line 2 and another didn't, check inside the wall plate. There are two wall-plate styles. The ones with a keystone jack needs the conductor wires pushed down into the correct slots. A punch-down tool is available from most hardware stores in the wiring section. The screw terminal type requires the individual wires to be stripped and then secured. The correct terminal positions are shown here: http://www.lanshack.com/wire_phone_jack.aspx . Otherwise, you need to trace the wires in the walls to find the break in the continuity. Your phone company will do this for you for a fee. If you have a line filter inside, try replacing it.
I hope this helps.
(I've called the phone company several times when we lost one line. Mice and lightning damage to the filter have both been culprits.)
Jul 08, 2013 | Lands Phones
Instructions for set up of... plantronics s10 head set and mic to a dsl box and also to use a magic jack.....I only have one phone line and am trying to figure out how this os done???any help would be very...
The S10 amplifier/headset system sets up like the Plantronics S12 system of which the user guide is included in the link below. As you will notice, it is designed to work with a telephone. It will not work as a stand-alone unit. To connect it to a dsl box, magic jack or any other line you will need a phone.
Plantronics S12 User's Guide
Oct 10, 2011 | Plantronics (45647-04) for S10, T10, T20...
For headset use - phone has a female rj-11 connection - the headset I am using has 3.5mm male connections for speach (mic), and for earphone. Do you have an adapter than can accomodate - male RJ-11 to...
First, we want to clarify that the headset connection is an RJ9 (RJ11 is the phone cable to the wall and the clip is larger). Plantronics doesn't make any such adapter but it is available online, just type "converter rj to 3.5mm" and you should get some leads to check out.
Good luck from Headsets Direct - 800-914-7996.
Aug 15, 2011 | Plantronics Headset Telephone Headset
Dont know how to hook it up to phone...have S10A and S11 model plantronics corded headsets
Turn over the S11 base and insert the headset slot. This is at the top of the base. Remove the handset cord from your telephone base and plug into the handset jack (there will be a picture). Using the short cord that came with the S11, plug into the line jack on the back of your base and the other end into the slot on your telephone where you removed the handset cord. Plug the headset cord into the headset jack that is on your S11 base. Connect the the A/C power adapter to the S11 A/C jack and a wall outlet. Put on the headset. Press the handset/headset switch and pick up the handset off your telephone, set it aside to make calls. Slide the configuration switch (on the side of the S11 base) until you hear a clear dial tone.
Aug 24, 2010 | Plantronics (45647-04) for S10, T10, T20...
I need the pinout for the Avaya 2400 series telephone headset RJ-11 Jack.
I noticed that Avaya headset is different from the Avaya handset or any other standard headset: The outer two pins are switched.
Avaya-Headset-pinning is like this:
Look to the RJ11 and turn it until you see leads from top and from front, then from left to right you look at
1) mic 5V
2) speak
3) speak
4) mic gnd
RJ11 of Avaya-handset and any standard headset/handset from the supermarket:
1) mic gnd
2) speak
3) speak
4) mic 5V
Hope that helps.
Stefan
Nov 24, 2009 | Avaya 2420 Corded Phone
How do i connect a telephone wire to an rj11 plug. What is the order of the wires for us telephones.
dialtone should go on the green and red wires of the jack for 1 line service, yellow and black for a second line.
Depending on the type of wiring that your dealing with the color code can change. if your wiring has white wires with little dashes of color on them then the code is:
green = white/blue (mostly white with blue dashes)
red = blue/white (mostly blue with white dashes)
black= white/orange (mostly white with orange dashes)
yellow= orange/white (mostly orange with white dashes)
Oct 23, 2009 | Lands Phones
How can I get connected the fax line? What are to
On the back of the unit you'll see 2 rj11 jacks. Those are the standard telephone jacks. Use a standard telephone cable (male rj11 on each end. Put one end in the lower jack and the end into the wall jack for your FAX line.
Jun 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon phonefax cfx-l4000
Connect a 4 wire RJ11 telephone cord from the wall jack to the jack on the machine marked"line."
Dec 19, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Plantronics (45647-04) for S10, T10, T20 Consumer Headset Logo
150 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
