Question about Bosch 24 in. SGV57T03GB Built-In Dishwasher
Pump starts as soon as main switch is turned on, even with door open. Also does not even try to fill. Does count down if you close the door and let it run but no water so no effect. I am guessing control board or anti-flood? Thanks
    President:
  • Bosch Master
  • 1,922 Answers
Is your door switch defective,that will cause same symptoms
Posted on Oct 03, 2009
Drain pump running as in flood protect mode even with door open, At first I thought the float was sticking due to sludge deposit.
The main controller and circuit board may have a short. Switches take their instructions from the main board and if a power surge or power outage occurs, one or more diodes, resistors or capacitors are faulty.
Mar 30, 2015 | Bosch Dishwashers
Superba 8524570
Is there something stuck inside, underneath, being turned along with the motor? burning smell usually means something got caught and the belt snapped. Not expensive and don't know if it's an easy DYI. Shouldn't cost too much to have it repaired or you can google the brand and model and the word belt, see what you find.
Mar 01, 2014 | KitchenAid Dishwashers
Driver door open message is on even when door is closed
should be on the door post or maybe in the closer mechanism..most are faily close to one of the door hinges..
Dec 31, 2013 | 2010 Cadillac CTS
I have a model number EM925RSL-B and the timer counts down but it does not heat up or turntable does not move?
I just bought an RV with the exact same microwave and the exact same problem. The problem with mine is the switch that detects that the door is closed is not getting activated. The reason for this is is the finger at the top of the door is damaged as well as the plastic piece that the finger grabs onto when the door is closed. This causes the finger not to come into contact with the switch. To test this you can turn your microwave on and start it. open the door and using a small screwdriver, depress the micro switch you can see upper right side of the door opening. then press start again. your turntable will start turning and the microwave will make a louder noise as a fan will turn on. CAUTION! Release the button as soon as you see the turntable rotation as you will be receiving microwave energy due to the door being opened.
Jul 02, 2011 | Microwave Ovens
I have a Bosh Logic dishwasher SGS65L12GB/04 The other day it got to 1 min left and would not stop pumping out water and continued even with the door open. After 5 mins playing around it started working...
Hi Jonathan,
Welcome to FixYa.
Your float may have got stuck or it's possible that you have water leaking into the bottom of the washer. In the bottom of the wash compartment, next to the drain you will find a plastic dome/mushroom (the float). You might need to rotate the bottom spray arm to see it.
Turn the washer on so that the pump starts to run, open the door and push down on the float. This should stop the pump running. When you let go of the float, if it rises back up on its own, then it's almost certain that you have water in the bottom of the washer. If this is the case please post back for further assistance. If the float stays down, then it may have simply got stuck.
Please try this simple test and post back with the results.
Regards,
BElectric
Nov 11, 2010 | Bosch Dishwashers
Whirlpool commercial washer stopped running mid
Most likely the pump is plugged with lint, pillow stuffing, a small object, or some other obstruction which is not allowing the motor to turn.
Oct 29, 2009 | Whirlpool Washing Machines
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
GE dishwasher GLD6300 series will not start. Appears to be on delay (2h) start/reset does not cancel it and it isn't counting down in the window.
remov power to the machine for 5 min, try new cycle if not check the door switch if it checks good replace the control board
if either of the door switches checks open with the door closed replace the door switch
May 03, 2008 | Dishwashers
Code de
de is 'door error'. I just fixed this with a new door catch/switch (called a door overlock). Theres a bi-metal strip in there that makes the contacts as well as keeping the door locked closed when its working and it looks like this was the culprit as I was able to open the door even when the machine was filling. The de was intermittant, if you continued to open and close the door it would start eventually - if it does this try changing the switch, cost about £30.
Feb 21, 2008 | LG WM-2277HW Front Load Washer
E60 error code
Found These Fault Codes On Internet, Hope This Helps, Daz
ALARM CODES
E00(E00)- Problems with water fill during washing
-Tap closed; solenoid valve, water distributor, wiring ,main PCB, pressure switches
E01(E00)- Problems with water fill during drying
-Tap closed; solenoid valve, wiring , main PCB, pressure switches
E10(E10)- Problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
E11(E10)- Problems with water drain during drying
-Drain hose kinked, filter blocked, drain pump, pressure switches
E20(E20)- Door open
-Cycle in Door delay, wiring , main PCB
E21(E20)- Fault in door delay power triac
-Wiring , main PCB
E30- Fault in electronic pressure switch
-Electronic pressure switch, wiring , main PCB
E31- Fault in electronic pressure switch circuit
-Main PCB (fault in electronic pressure switch circuit)
E32(E10)-Calibration error in electronic pressure switch
-Electronic pressure switch, drain pump, wiring , main PCB, filter blocked
E33- Incongruency between electronic pressure switches and safety switch 1
-Electronic pressure switch, safety pressure switch,wiring, main PCB
E34- Incongruency between electronic pressureswitches and safety switch 2
E35- Intervention of anti-overflow pressure switch
-Solenoid valve, water distributor, wiring, main PCB,anti-overflow pressure switch
E36- Water leakage (maximum number of resets exceeded)
-Water leakage, drain hose too low, pressure switch,wiring, main PCB
E40- Motor power triac short-circuited
-Main PCB (triac short-circuited)
E41- No signal from tachimetric generator
-Tachimetric generator on motor, wiring, main PCB
E42- Fault in tachimetric generator circuit
-Main PCB (tachimetric generator sensing circuit)
E43- Intervention of motor overload protection
-Motor, wiring, main PCB
E50- Insufficient heating during wash phase
-NTC sensor setting incorrect, heating element, wiring,main PCB
E51- Overheating during wash phase
-Heating element (to earth), main PCB (relays)
E52- Insufficient heating during drying phase
-NTC sensor setting incorrect, safety thermostat,thermostats, drying heater, wiring, main PCB (relays)
E53- Overheating during drying phase
-Drying heater (to earth), main PCB (relays)
E55- Fault in power relay for heating element (K3)
-Safety pressure switch 2, wiring, main PCB- 6 -
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
E61- Fault in drying NTC sensor(condenser)
-Drying NTC sensor (condenser), wiring, main PCB
E62- Fault in drying NTC sensor(duct)
-Drying NTC sensor (duct), wiring, main PCB
E63- Fault in 1/2 power thermostat
-Drying NTC sensor (duct), 1/2 power thermostat, wiring,main PCB
E70- Power triac to distributor motor short-circuited
E71- Fault in power relay to distributor loads
-Main PCB (relay open)
E72- No distributor position signal
-Water distributor motor, wiring, main PCB
E73- Incorrect timing on distributor contacts
-Water distributor, wiring, main PCB
E90- Fault in tank fill pump
-Hoses obstructed, tank fill pump, wiring
E91- Fault in tank drain pump
-Hoses obstructed, tank drain pump, wiring
E92- Fault in power triac to tank fill pump
-Tank fill pump, wiring, main PCB
Jan 04, 2008 | Zanussi ZWF1440 Front Load Washer
Bosch 24 in. SGV57T03GB Built-In Dishwasher Logo
218 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
