Question about Philips DVP3140
PAL problem Hi, I would like to get some info how can I "add" PAL system in my Phillips dvp 3140 DVD player setup options. There is only NTSC sytem, no other possibilities to choose like PAL or Secam can't change.
  • sameermv Dec 27, 2007
    I have PAL TV system, I am not able to change the DVP3140 DVP players option to PAL system. Only one option is given under menu 'Video -> TV System -> NTSC'. Please suggest how can I change it to PAL system?
  • reservations Jul 14, 2008
    Having the same problems....have your come up with any solutions....thanks
    Problem Solver:
  • 9 Answers
Hi!
The DVD player you have is only compatible with NTSC TV. There is no way of changing that to PAL.
It is compatible though with PAL discs. It will convert the video signal of a PAL disc to NTSC format.
Posted on May 18, 2008
Hi, I have bought in US a SONY DVP-FX950 and took it back to Germany. Unfortunately I can not watch any DVD , I think because of NTSC only and Region Code 1. I do not want to bin this nice device, so I...
Hello Sir
As I know, transmission and receiving system in Germany is PAL. A PAL system only device annot be set to NTSC or vice versa. You also knows that. How 625 lines system can be converted to 525l lines system. Normally, all sets released in US is meant for use in US only. The set will have strict quality control measure also.
I don't know about the technique, to change NTSC to PAL. If a converter which can make system convert, you may have use this device I thinks. As an engineer, just try to get this type of converter in Germany. OK.
Apr 23, 2011 | Sony DVP-FX950 Portable DVD Player
Will the dvp 311ok play ntsc dvd i am in australia and i am reg 4
As long as the NTSC DVDs are not region coded, and your TV is multi-standard (able to receive NTSC as well as PAL signals via A/V inputs or similar connections), the player should play NTSC just fine through it
I assume this is a PHILIPS player? If so, most PHILIPS DVD players support NTSC playback on PAL TV.
You are correct, Australia is region 4 for DVD standard. The only restriction would be region codes.
Feb 27, 2011 | Televison & Video
I have a Philips DVP-3010 DVD player which I purchased in Europe and thus it was set to PAL video output mode. Connecting it to a US television (which understands only NTSC) and playing a DVD produces a...
Check that the TV doesn't have the option to display PAL transmissions. It might be able to do it via any of the connectors. Otherwise your best option is to find a TV that can indeed convert both signals, or get a converter box.
Apr 04, 2017 | Philips DVP3020 DVD Player
When you insert a dvd it says PAL DISK
PAL is the format of the dvd and there are two main formats for a dvd and they are PAL or NTSC. The NTSC format is mostly used for the United States, and the PAL format is used more in Europe and Asia. An older dvd player will have the format options in the setup menu for the dvd player, and from the setup menu on the tv screen the dvd player can be set to play the PAL dvd's. However if that is not the problem and the dvd player no longer can tell a PAL from a NTSC format then the dvd player either needs a serious lens cleaning or it has a malfunction. Also, the back of the cover for the dvd should say if it is PAL or NTSC.
Jun 16, 2010 | JVC TH-A9 System
I hav a phillips mini hi-fi dvd player that doesnt want to play english dvd's.it keeps on displaying wrong region eventhough it played it before. pls assist. thanx shaheeda
this sounds like pal and ntsc issues um what dvd you use ones from retail walmart,bestbuy ect or homemade dvd movies ?,try different brands of dvd ,try to go to the options on your dvd player and set it to ntsc if not try to clean the lens also ,hope to hear from you for more help.
Sep 14, 2009 | Audio Players & Recorders
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
cheers,
mark
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
Black & white resolution
good day,
Possible reason would be Video system compatability. In PHI most of the screen are NTSC compliant for video sytem and for Qatar im not sure if its PAL or PAL SECAM system. But no worries, the only thing you need to do is change the video setting of your DVD player. do you have the owner manual of your player? if do so, check for the part reffering to video system. access that menu and one part of that selection would be the video out system, there should be a selection to choose from PAL/NTSC and auto. just select "Auto" or "NTSC"
cheers,
mark
Jan 31, 2009 | JVC XV-N652
Philips dvd 3445h doesn't seem to support pal format
You would have to either convert the DVDs to NTSC by ripping them to your computer and using conversion software, or you need to get a player that supports PAL and NTSC. Phillips has players that do both NTSC and PAL but it sounds like the one you have doesn't.
I have a Phillips DVP 5140 that does PAL and NTSC and is region unlocked.
There are other players on the market that do support it, but you will have to look around a bit.
Best of luck
Jan 04, 2009 | Philips Televison & Video
PAL mode ?
PAL/NTSC is automatic. if you insert a PAL DVD output is PAL ( most probably PAL-B. Some other brands allow manual PAL/NTSC switching, but at this machine this is automaticaly done. Please verify your TV set allows PAL programs
Oct 27, 2007 | Sony DVP-NS50P DVD Player
Philips DVP3140 Logo
202 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
