Question about Dryers
Why is my dryer only blowing cold air? (yes I have adjusted the settings)
    Genius:
  • 1,474 Answers
Could be element or thermostats..Make sure reset if one on ok 1st
Posted on Oct 03, 2009
Why does the drivers side A/C not blow cold air out?
It may have climate control rather than air con, this might be the caue.... It might be the adjustment needs to be changed...maybe it is just set that way??
Apr 26, 2014 | 2008 Hyundai Azera 3.3
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Simpson Dryer only blows cold air
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Washing Machines
When I turn on the heat in my 2004 mazda mpv the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
When I turn on the heat in my 2004 mazda mpvicon1.png the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
Jan 14, 2011 | 2004 Mazda MPV
My dryer only blows cold air I replaced the
Yes it is quite possibly your thermostats, A kit can be purchased for the majority of all Whirlpool dryers and is around $30.00 part number is LA-1053. But it can vary based on your model. However the first place i would have technician check is the fuses or breakers inside your home as this can often cause the dryer to only run on 110v when 220v is need to run both the motor and the element.Hope this helps.
Thanks
Nov 22, 2009 | Whirlpool Dryers
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
Blows cold air , it still spins, but doesnt heat up.
Is this a condenser dryer or vented?
On the condensers, if the water collector is full it will only blow cold air. Sometimes the water pumps that bring the water to the collector bottles can go and it makes the dryer think that the bottle is full, therefore it will blow cold air.
Hope this helps!
Aug 13, 2009 | Maytag Dryers
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
87 people viewed this question
Top Dryers Experts
