Question about HP Photosmart 945 Digital Camera
Flashing lights I was using the camera and it just froze, and now the display screen and red light are flashing and it wont turn off. How do I stop this or reset the camera?
  • luistovarvet Jul 02, 2008
    Great. I have the same problem. Apparently it began after leaving the camera connected to a USB Port (PC), turned on, during a long time. I am using now rechargeable batteries. I have taken the batteries out during long periods but it is the same. Taking the Memory card did not help. I will try leaving it 2 days and then insert new batteries.
I read your posting about changing the batteries. I tried it once and it did not work. Then, I tried it again a few weeks later and the new batteries made it work. I have not tried the rechargable batteries again. I am afraid to remove the batteries I placed in the camera. I hope this helps you. I think there must be a sensor that gets reset at some point and the issue stops. Who knows. Good luck!!!
HP also suggested to reset the camera as follows:
To Reset The Camera:
1. Remove the memory card and turn on the camera.
2. Open the battery compartment and remove the batteries.
3. Wait at least ten seconds.
4. Reinsert the batteries and turn on the camera.
I also found information regarding a similar problem with another model at this link:
Focus Assist Light and LCD Flash Simultaneously
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=de&cc=ch&dlc=de&docname=c00240207
The Issue:
When the HP Photosmart digital camera is placed on the dock without batteries, the AF assistance LED and LCD could blink at the same time. Explanation It seems that the super-capacitor on the camera senses the voltage supplied by either the AC adapter or batteries when they are inserted. This is more an annoyance rather than an actual failure on the device. The microcontroller (Dang) senses the voltage and sends a signal to the LCD and AF assistant LED. This is what some times is called a WAD (working as designed). If batteries are present or the super-capacitor is charged, the AC adapter will not trigger this behavior. This can be tried by inserting some batteries on the camera for 3 or 5 minutes, then remove them and place the camera on the dock. No blinking should be present.
Posted on Mar 17, 2008
Sigma EF-530 DG ST - not working, on test or camera all 6 LED lights displaying. Any thoughts?
I don’t usually play with flash that isn’t built in- I prefer natural light, but...if this were me I would: A) take very fine sandpaper and very lightly go one time over all contacts for the flash and camera. B) I would also see if my button batteries in my camera needed changing. As I remember they have something to do with recognizing lenses and flash attachments. C) I would also make sure the batteries in the flash, although changed, were making proper contact with the battery terminals and might also lightly sand those as well since the flash is little used.
Jan 10, 2018 | Sigma EF-530 DG ST for Pentax TTL Flash
Laptop froze now wont restart
remove the laptop battery and turn it on now check the led indications
May 09, 2012 | Toshiba Satellite Computers & Internet
JVC GZ-MG680BEK No display. Can't use camera. I
Ok silly question you have removed the lens cap correct?
Apr 22, 2012 | JVC Video Cameras
The camera wont turn on
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
Apr 04, 2009 | Kodak EasyShare C743 Digital Camera
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
It wont turn on
Check the memory card try to turn on the camera without the memory card if that works problem with the memory card if that doesnt work...... Try using a diffrent set of batteries...... Still doesnt work...... Get the camera replaced..... Good Luck....
Jan 19, 2009 | Nikon Coolpix L11 Digital Camera
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
HP Photosmart 945 Digital... Problem
Remove the batteries and SD card for about 5 minutes. Reinsert and see if that resolves the issue..
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Red power light flashing on and off
the same thing happens to me! idk how to fix it
May 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
HP Photosmart 945 Digital Camera Logo
303 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
