Question about Garden
Craftsman Trimmer/Edger 4.0 HP Engine races...
Craftsman Trimmer/Edger 4.0 HP Engine races... Throttle moves ok. But its either slowest setting... any movement toward fast and the engine revs really fast... out of control. What could be the problem?
  • 148 Answers
Most likely, the mechanical governor is damaged inside the engine. If you have tools, a sense of adventure, and lots patience, this can be replaced for a modest cost in parts.
If not, take it to a reputable repair shop.
The governor replacement involves engine removal, opening the crankcase, lots of parts-cleaning, and attentive reassembly.
Would be happy to help you if you decide to tackle this repair.
Hope this helps.
Posted on Oct 04, 2009
Stihl fc 44 edger blade not moving when I press the throttle
check both where the shaft attaches to the motor and also to the guard housing. they sometime vibrate loose and need to slide back in place. also the clutch can wear out.. try the shafts first...
Sep 07, 2012 | Stihl Fc, 36, 40, 44 Trimmer Edger Clutch...
Setting the govener
You should not be messing with the governor. The governor wants to slow the engine down. See which direction the throttle shaft needs to travel in, usually from the carb to the governor, to close the throttle butterfly, NOT the choke plate. Loosen the governor clamp, rotate the shaft clockwise while holding the governor in the same direction. Use your head to determine how to make these things happen while tightening the governor nut back up. The engine shouldn't race, and the throttle cable should now work. I shouldn't have told you any of that. Ok, here; if your motor blows up because you do something wrong, I TOLD you not to mess with the governor BEFORE I explained how to adjust one. But that's how you adjust one.
Jun 09, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
4 hp craftsman edger/trimmer. Not getting a clean cut anymore on my grass.
Does this one have a metal blade? If so the blade is removeable for replacement or for sharpening.
Aug 06, 2011 | Craftsman Garden
My 29cc 4 cycle craftsman gas trimmer loses power when I increase the throttle
While Holding the Engine at Full Throttle, Adjust the High Air Mixture Screw In Until the Engine Revs Properly.
Jul 01, 2011 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
May 27, 2009 | Craftsman Gas Mini - Tiller/Edger
Need parts for craftsman edger/trimmer 275.796432
Here's a link to sears parts website
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Mar 21, 2009 | Garden
Garden Logo
264 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
