Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
Same Problem What kind of gadget do you use to remove the screws? I can't feel any grooves on the screws, so they can't be cross or phillips. I'm not sure what the gadget is called, hexa something??
    Genius:
  • Whirlpool Master
  • 1,466 Answers
You can buy tools to do this or use a fine flat blade driver providing they are not too tight .... torx screws..
Posted on Oct 03, 2009
Testimonial: "Thanks for the name! torx screws."
How do I replace the petrol primer bubble
simple !! just obtain a Ryobi fuel system repair kit (any Ryobi dealer ) , this includes a new primer button , unscrew two Phillips screws holding clamp ring down around bubble (save them) remove damaged bubble (all of it, sometimes leaves behind bits of it) install new bubble and verify it's down in groove , reinstall clamp ring and screws , fill fuel tank and prime button (pushing it )
Apr 20, 2015 | Ryobi Garden
I need help changing the be belt on a Dewalt 734 planer.
Installing a New Belt
NOTE: No tools are necessary to install a belt. The use of a
screwdriver or other tool to pry or stretch a belt may cause
damage to the pulleys and ultimately destroy the new belt.
1. Remove the crank handle.
2. Remove the two hex screws from the top, right side of
the planer.
3. Remove the two, small cross head screws securing the
side panels to the top of the planer.
4. Lift the side panel up out of the slot in the base and
remove the panel from the machine. Notice the grooves
inside the belt.
5. Start the belt on the top pulley (P) with 3 grooves on the
pulley, as shown in Figure 22.
6. Guide the belt between the lower pulley and the height
adjustment screw (Q), as shown in Figure 23.
7. With three grooves engaged on the large pulley, rotate
the pulley clockwise. Keep pressure on the edge of the
belt to keep the grooves engaged on the small pulley.
8. Continue pressure on the side of the belt and rotate
the large pulley while hopping the belt further onto the
pulleys, as shown in Figure 24.
9. All of the belt grooves should be engaged in the final
position and the pulleys should rotate smoothly.
10. Reinstall the side cover and the screws. Do not
overtighten the self-tapping screws.
Mar 03, 2015 | Dewalt DW734 Heavy Duty 12 12" thickness...
How to replace rear rotors from a 2007 hyundai veracruz
The Phillip screws hold the rotor in place...they must be removed! Sometimes they ar e difficult to remove...spray liquid wrench and let sit for an hour or so...use a ratchet Phillips drive with the correct size bit or you will ruin the Phillips heads.
Sep 15, 2012 | Hyundai Veracruz Cars & Trucks
Replace bellow seal
Hello.
1 Unplug the power cord. Pull the Whirlpool Duet away from the wall. Remove the screws at the back of the machine using a Phillips screwdriver. Remove the top panel from the machine and set it aside.
2 Remove the soap dispenser from the front of the machine by pulling it out and depressing the button at the back to release it. Remove the soap dispenser bracket retaining screws, using a Phillips screwdriver. Pull the dispenser bracket out of the washer.
3 Remove the retaining screws from the control panel with a Phillips screwdriver. Release the locking clips and flip the control panel on top of the machine. There is no need to disconnect the wiring harness. Open the washing machine door and remove the retaining screws from the door latch, using a nut driver.
4 Remove the outer retaining spring from the bellow seal using a pair of needle-nose pliers to grasp the loop and pull it out. Peel the bellow away from the door opening, using your fingers. Push the bellow seal inside the machine after you release it from the door opening.
5 Lift the front of the washing machine and put a wooden block under it.
Remove the retaining screws from the bottom of the front panel using a nut driver. Remove the wooden block from under the washing machine and lower the unit back to the floor. Remove the screws at the top of the front panel with a nut driver. Pull the panel away from the machine and set it aside.
6 Pull the old bellow seal from the machine. Unplug the white and black hoses from the old bellow seal . Remove the spring clamp from the bellow and throw the old bellow seal away. Rub liquid laundry soap on the groove of the new bellow seal. Push the new bellow seal onto the washtub with the opening for the hoses at the top. Push firmly until it is on tight.
7 Install the spring clamp on the new bellow seal into the groove using a Phillips screwdriver. Plug the black and white hoses into the holes at the top of the bellow. Be careful not to damage the bellow seal. Place the front of the machine on the frame and install the top screws using a nut driver. Push the door latch through the hole and install the retaining screws.
8 Press the bellow seal into place around the door opening and install the spring clamp around the perimeter of the bellow. Lift the machine and place the wood block under it. Install the bottom screws with the nut driver. Remove the wooden block and place the machine back on the floor. Put the control panel in place and lock the retaining clips.
9 Install the soap dispenser bracket and the retaining screws using a Phillips screwdriver. Install the retaining screws on the control panel. Place the top cover on the machine and install the screws with the Phillips screwdriver. Plug in the power cord and push the machine against the wall. Install the soap dispenser drawer and push it all the way in so the tab locks into place.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
I need to remove the front door panel in my Lexus 430 LS front left side.
I am going to asume your replaceing the window motor and give you that procedure so you may wind up with a little more then what you asked for.
Oct 20, 2010 | 2001 Lexus LS 430
I need to remove the headgear from my dripping hot tap in the bathroom which was fitted circa 1999 I have taken the plastic cap off and then faced with a screw head I do not recognise, it is neither a flat...
you wont cross thred it all you will do is grind away the head of the screw and then you will never get it out, i know the screw your talking about it looks like a phillips but its not a phillips,,,it a No8 bit! you need to get a kit of bits to undo this screw,,,i wonder who thinks thees screws up???
Mar 27, 2010 | Plumbing
I need to remove the luggage racks from my 2007 Hummer h2 SUT
I have the same vehicle and was able to remove mine with the following steps: 1) remove light behind each rear of luggage rack rail using phillips screwdriver (one screw each side). 2) remove molding underneath each light using T20 torx driver (2 screws each side). 3) Loosen cross rails nobs. 4) Side cross rails off of roof.
Nov 27, 2009 | 2007 Hummer H2 SUT
How to remove 1990 xj6 radio
You must open the center console lid and remove the 2 Phillips head screws above the fuse station to expose the ashtray Phillips head screws.Remove the ashtray screws and carefully pull he ashtray back towards the center console. After the ashtray is removed take your hand an feel under the wood grain unit for the 2 plastic wing nuts holding the wood grain in place. Remove them and gently lift the wood grain up and out of the way. Remove the 4 Phillips head screws holding the AC controls and Radio bracket. Place the gear shifter in drive to pull the whole unit out. Sounds like a lot but takes about 10-15 mins to complete.
Aug 29, 2009 | 1990 Jaguar XJ6
Changing the belt
flip over
remove 3 phillips head screws and remove cover
pull agitator roller out of groove opposite end of drive belt area
install new belt by putting loop around silver drive shaft then putting over belt roller
put roller in appropriate grooves( belt will feel stiff make sure belt stays on roller and under drive shaft put cover back on
You are ready to go!
Jan 03, 2009 | Eureka Luxury Family 8-Person 2-Room Titan...
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
