Question about GE Microwave Ovens
JE2160SF03, Microwave: The paint on the inside bottom section under the wheels is coming off. How can I fix this?
tiway1
  • 100 Answers
SOURCE: Rust inside the microwave.
The areas can be sanded and painted, but first make sure there are no holes rusted through. If it's all surface rust, then sand and clean as best as you can. If you have any areas rusted through - get rid of the microwave.
Use the paint sparingly - don't try to cover in one or two coats. Best results are obtained with very, very light coats drying 10 minutes or so (depending on the humidity) in between. 10- 15 coats usually works well.
It's best to do this outside, as you'll have lots of overspray.
As far as the paint - the best I've used for the last 20 years or so comes from A.M.I. Parts. You can find them @ www.amiparts.com or toll free 1-800-522-1264.
Posted on Jul 04, 2008
IrishDruid
  • 2712 Answers
SOURCE: Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
Posted on Nov 15, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: rust under turntable of microwave can i paint it?
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Jun 02, 2009
  • 228 Answers
SOURCE: paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Posted on Jun 20, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: the bottom of my microwave
Probably, as long as it's not rusted all the way through.
You need to sand it to bare metal, then it will take paint.
I'd leave the door open and let it dry overnight.
Posted on Aug 22, 2010
The bottom inside part of my Oster microwave is peeling up pretty bad where the plaste circle with wheels turn the glass. Don't use it much for this to happen....is it still safe and is there any recalls...
Using the microwave with exposed metal can cause additional problems. You can remove the loose paint, lightly sand the area and reprint with microwave cavity paint. The paint can be purchased from your local parts distributer, or find it online. Follow the instructions on the can.
Jul 21, 2014 | Microwave Ovens
Wheels under ring have wore paint off.. Can and what can I RE-PAINT THIS WITH
you can go to www. repairclinic.com and get it the parts necessaryGod bless you
Apr 04, 2013 | Sunbeam Microwave Ovens
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
Paint inside microwave is chipped and blistered. How do you fix it?
HI,
If you are able to spent money for a new Microwave then go for a new one.
If you are interested to repair and reuse the existing Microwave then keep on thing in mind, if you paint it then also it will not lasts for a long time as the metal underneath is rusted.
Ajin
Jul 14, 2012 | GE Microwave Ovens
The bottom of my microwave (under the wheels of the turntable) is starting to chip. can i repair this myself with high heat appliance enamel paint?
Aug 22, 2010 | Microwave Ovens
Paint inside microwave oven bottom is peeling
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Painted finish coming off inside of jenn air microwave
You will have to look at the hole picture to see if it cost feasible to have this repaired under warranty.
If this is tripping a breaker you should not use it. But for the most part it would be better to look at getting a new one.Sorry there is no easy way to take care of this, so I hope its under warranty and they replace it for you.
Mar 23, 2009 | Microwave Ovens
My microwave is rusting inside. mainly the area where the turning wheels meet the base. I have sand and painted with microwave paint but after a few weeks the paint area around the wheels is rusting again.
try the microwave touch-up paint again but this time clean the spots you sanded with rubbing alcohol. also make sure the rollers turn freely
Jan 31, 2009 | Microwave Ovens
Ge microwave model # JE2160SF03
Sounds like rectifier gone.Needs testing by microwave engineer
Oct 09, 2008 | Microwave Ovens
Microwave Ovens Logo
123 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
