Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
Toilet keeps running even when manually lifting floater to max
This is an Ingenium type flusher
  • 20 Answers
Check handle to ensure no tension is on the flapper chain when not being flushed. check flapper to ensure positive seal to flush valve. check water level to ensure not overflowing into flow valve. if that's the case, lower water height.
then if still doesn't work, change flapper,
all else fails, change flush valve.
good luck,
steve
Posted on Oct 12, 2009
Can't get the top off of a Thetford toilet
If it's a top flusher screw the flusher anti clockwise as its attached to the internal parts once in screwed the top will just lift off
Sep 22, 2014 | Sport & Outdoor - Others
Kohler toilet troubles
The holes around the inside of the bowl may be clogged, try using some CRL and scrubbing the holes with a good stiff brush.
Apr 09, 2014 | Kohler Toilet - One Piece with Ingenium...
I have a kohler model 703 # sb78drn, the toilet keeps running. i changed the flapper and now the toilet doesn't stop running. please help?
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Mar 04, 2011 | Kohler Toilet - One Piece with Ingenium...
Float does not trigger valve to stop water - continues to run even though tank is full
What kind of flush valve is it? kohler.com shows a couple of different towers with their ingenium toilets. Is it a Kohler item or is it a Fluidmaster?
Usually you adjust water height by turning a threaded rod that runs up and down. See page 5 of this pdf
http://www.plumbersurplus.com/pdf/1058802_2.pdf
Jan 29, 2011 | Kohler Toilet - One Piece with Ingenium...
Toto toilet is constantly running, even though the tank is full
it sounds like it might be the floater ball in the toilet you can adjust the tension on it usually with a screwdriver.... if you look from the top down you should see a screw on the top of the arm that holds the floater adjust the tension and hopefully this will work
Jan 20, 2010 | Toto Drake ADA Compliant Toilet with...
Why does the water go over the top of the float
bend float down to adjust water level if water is covering float and still not stopping some flushers have an adjustment screw on top also turn slowly a 1/4 turn at a time if still doesnt stop lift float until stop bend rod to adjust if water doesnt stop from lift than diaphragm in flusher bad and have to change out again
Oct 06, 2009 | Home
Toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Jul 03, 2009 | Kohler Toilet - One Piece with Ingenium...
Toilet Keeps running
try adjusting the floater valve >>bend brass rod down 1/4 inch untill you can not hear water comeing through
Jun 07, 2009 | Home
How do you get the top plastic cap off the Kohler Ingenium flush
My Kohler Ingenium has no pins. The white cap is attached to the grey lever which must be lifted up before twisting both one-eighth turn counter-clockwise, and lifting off of fill tube. Turn the water supply back on and flush the tube out (cover with cup first!). Use a thin wire rod about 12" long to gently poke down into fill tube to clear any clogs. Also check where the small flexible fill tube exits from the main fill tube. Reassemble and cross your fingers.
Mar 26, 2009 | Kohler Toilet - One Piece with Ingenium...
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
713 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
