Question about Toshiba Satellite A100-S8111TD Notebook
My laptop keeps shutting down at random times. I
My laptop keeps shutting down at random times. I hear the fan running, I make sure that there is space allowed for air movement and when it does it it doesn't necessarily feel that warm. When it shuts off, I can turn it back on immediately and it will run fine for a a while or it might stay which makes me wonder if it is something other then overheating.
  • 154 Answers
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck
Posted on Oct 04, 2009
  • 329 Answers
Its not like overheating.....It could be Hard drive problem or RAM problem...........check for any bad sectors in hard drive or try replacing RAM.....
Posted on Oct 03, 2009
I recently got a new battery for my HP DV7-1245dx and it still powers off randomly. I trust it isn't a battery issue for it seems to only shut off when in actual use. Please help me with any...
Could be due to the system overheating; does it run hot?
Try using it on a hard flat surface to see if it runs better, allowing better airflow around the machine and check the fan is running, you should be able to hear it.
If it's overheating, it will shut down to prevent heat damage. Overheating can be very destructive to pc components. You'll need to open the case to get to the heatsink, fan and vents. Remove the fan and heatsink and clean. Clean all the vents with vac or compressed air. Apply a little thermal paste to the processor and replace the heatsink and fan.
Mar 29, 2012 | HP Computers & Internet
Question about a fujitsu lifebook P5010. when i power up i have a blank/black screen although i can hear the fan running constantly. the little lcd display area next to the power button works. there are...
Hi insurancedud...
Try blowing the dust out of the laptop by using compressed air in a can or an air compressor, the compressor is the pefered choice (max air pressure 90 psi).
Blow the air into the fan discharge of the laptop, (be sure not to overspeed your fan) then blow the air into the intake of the fan.
Do this a few times until you have no more dust in your laptop.
Then see if that cooled it down, if not maybe your fan is faulty and not cooling properly.
You can also put a cooling pad with fans under the laptop to help cool , they have the laptop coolers with usb power.
Please take time to rate me thumbs up
Sep 11, 2011 | Fujitsu Computers & Internet
I have a Toshiba laptop with a Windows 7 operating system, a few years old. It recently started randomly shutting down - after 10 minutes or so of use, it would just go dead. It's also extremely slow,...
Hi.
the first thing i would check is to make sure there is no dirt or dust stopping the fan from running because if the fan is not running it will heat up and shut down or if the fan is running slow it will shut down.
and for running slow i would do a good clean up get rid off stuff thats not needed anymore.like music,pictures,the more your harddrive has on it the longer it will take to load and run.
Oct 21, 2017 | Toshiba Satellite L455-S5975 Series Laptop...
Overheating problem with HP Probook 4510s
Laptops shut down when they overheat to protect themselves from damage due to heat. Can you hear the fan running on the laptop? If not, then take it in to a shop to be looked at, or contact the manufacturer if it is still in warranty.
I will assume that the fan is probably running at full blast all the time. if this is the case, then you probably need to clean the heatsink on your laptop. How?
An air compressor is best for this if you have access to one. A can of compressed air may work, but usually does not have enough pressure to clear it out.
Your laptop fan draws air in through the bottom of the laptop and pushes it through a heatsink. The heatsink is a piece of metal that draws heat away from the cpu (main chip on the laptop) and allows the fan to cool it. The fan blows air between tiny metal "fins" on the heatsink. You will probably be able to find where your laptop blows out the hot air.
Find where the hot air comes out of the laptop, and blast compressed air into that place. You will probably see a cloud of dust come out of the bottom of the laptop. Keep blasting air until no more dust comes out. Once this is done, the laptop should run quieter and cooler. Let me know if this does not fix the shutdowns.
Jun 04, 2011 | HP ProBook 4510s Notebook
My laptop keeps shutting off it is a hp pavillion dv6000
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 16, 2010 | HP Pavilion dv6000z Notebook
When i play games the laptop would shot down. prior to shutting down i could hear the fan of the laptop very loudly
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Sep 10, 2010 | ASUS Computers & Internet
Notebook keeps shutting down
there are numerous cases why the computer keeps shutting down. One is the pc is slow to react, the other is when the pc is in idle mode, it did not respond accordingly to its idle time to come back to its original settings. These are just the samples.
To solve this problem, kindly turn off the computer and remove the battery and cables to it. Then using your forefinger, press & hold the power button in between 8-12 secs. Then reinsert the cables and battery to it. Turn on the pc and let your computer be idle in 30 mins. If in 30 mins your pc will shut down, that means there is trouble on your memory module inside your laptop. The RAM (Random Access Memory) keeps your computer in safe and running condition for it is avoiding the pc to automatically shutdown. That is the time to consult ASUS about this issue...
Sep 02, 2010 | ASUS Eee PC 1000H Laptop
My 4 year old Acer Aspire 5520 notebook shuts off on me at random time periods. I try keeping it proped up and keeping it cool but that doesnt even seen to help. It doesnt over heat but just decides to...
Have you cleaned the cpu fan? The computer has a cpu fan that can get dirty over time. It's job is to keep the cpu cool. When the cpu overheats, the computer senses it and shuts it down immediately, to prevent permanent damage to the cpu. You can clean it by blowing compressed air into it, and should do that every few months, as routine maintenance. This is the most common thing that shuts a laptop down, other problems involve repair, so try this first. I bough a $7 three inch fan at Walmart to help cool the laptop, and when I run it, I never have it shut down on me, but once in awhile it will without the fan, especially when I play dvds or videos, which really work th' heck out of the cpu. There are also commercial laptop cooling devices, but my little fan works just fine. The other thing that could be happening is some problem with windows, which is something I couldn't begin to guess. Hope it's just a bit too much heat.
Mar 29, 2010 | Acer Aspire 5520-5908 Notebook
My acer aspire 5735 randomly shutting down
Try taking out your battery it might be shorting out just run your laptop from the adapter and see how long it lasts before it shuts down
Feb 22, 2010 | Acer Aspire 5735 Notebook
Acer aspire 5630 laptop keeps shutting down
It sounds like someone has suggested that overheating may have caused the random shutdowns (which is quite plausible). There are a few tools that can diagnose what is happening:
  • Temperature: I use SpeedFan (http://www.filehippo.com/download_speedfan/) to discover the temperature of my cpu. My Acer 5630 is usually doing 50 to 60 degrees. Anything higher than that could cause the random shutdowns (I've seen it happen on other laptops). If you download this program, don't muck around with the settings (as it would advise you not to anyway), just look at the temperature readings (eg. core 1 core 2)
  • I keep a cpu usage meter on my sidebar (http://gallery.live.com/liveItemDetail.aspx?li=587ef54f-e121-418b-b258-e583e105a0d6). It keeps an eye on the CPU usage so if i see it say 100% cpu usage then I suspect some software is inappropriately consuming resources.
Treatment of overheating would be to find the offending software and manage it or remove it. If it is not software at fault, then it may be that there is too much dust covering the ventilation (Your acer may be old and you may hear your fan increasing speed and the performance struggle sometimes). I opened up my one and found dust build up from the radiator all the way to the fan! (it was like around 1cm thick in some places, i wish i took a picture)
Another reason for random shutdowns is the integrity of the power switch or the lid sensor. My computer got rained on once and randomly shut down. It took a while of cleaning it with Circuit board cleaner from Repco (I had to open the panel that covered the power button and spray it). It got better everytime I cleaned it and now it reliably stays on (actually it randomly turns on now haha)
Jan 02, 2010 | Acer Aspire 5630 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
604 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
