Question about Hansol 920 A 19 in.CRT Conventional Monitor
Hansol 920A the geometry settings on my monitor are out of wack tried getting it to revert to factory setting didnt help and i also tried doing it manually but with no luck .Does anyone no where i can get the factory setting for the geometry of this monitor
2 Suggested Answers
SOURCE: original cost of Hansol Monitor
price is 389.99 dollars.
Posted on Feb 02, 2011
Display image is too small and off center.
change you cmos battery, configured your settings and off the machine for 5 mins. let on and observe if changes same.
Apr 13, 2010 | Hansol 900 P (White) 19" CRT Monitor
I am thinking of buying a used Hansol 550 - three years old. Do they deteriorate with age ? Do all the old models have speakers fitted ?
3 years old will more likely to need new set of caps, not all monitors come with built-in speakers. See failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
I would not buy a 3 years old 15", save the money for newer and bigger monitor.
Feb 10, 2010 | Hansol H550 15" LCD Monitor
My Dell E773c Monitor's image is like a "hyperbola" wider at the top and bottom and narrower in the middle. The Horizontal adjustments do not do anything to correct the problem, Help!!!!
Try to do a factory reset (look up "recall" in the manual, or here: http://support.dell.com/support/edocs/monitors/e773c/EN/ug/setup.htm).
If this does not help, you need to adjust the geometry settings (H/V position, H/V size, rotation, trapezoid, parallelogram, pincushion and pin balance) using the monitor's settings menu. Expect a long afternoon of fiddling around until you get a satisfactory result. A test picture for geometry settings could be of help.
Make sure your computers video setting does not exceed the monitors specification of 1152 x 864 @ 75 Hz.
Feb 04, 2010 | Dell E773C 17" CRT Monitor
Hansol710p 17"Monitor color adjustment problem
wich is factory colour profile from hansol 710p ? thanks in advance p.s. jovica.tasic@hotmail.com
Jul 25, 2009 | Hansol 710 P Monitor
Birghtness problem
Not much you can do. This could be a defective monitor. play with the settings and if you still aren't satisfied then contact the manufacturer to give them the feedback. They may replace it for you.
Jun 03, 2009 | Hansol H530 15.1" LCD Monitor
Brightness
open the monitor you will look big black part called EHT you will see the movable shaft on it rotate it by screw driver in active supply monitor see on screen suficient brightness and stop you will be satisfied
Nov 21, 2008 | Hansol 500 A Monitor
Resolution hansol 730E
interesting, have you tried perhaps a monitor screen?
Feb 11, 2008 | Hansol 730E 17" CRT Monitor
Screen Whine
Hi, constant high pitched whine from most monitors have something to do with the horizontal frequency which is partly affected by the screen resolution as set in your computer display properties. Try lowering down your resolution or go into safe mode. if the whine disappears, it may be that the monitor is not fully capable of displaying too high a resolution. If the whine continues even at safe mode or lower screen res, then you would need to consult a qualified technician to check for defective components in the horizontal circuitry of your monitor. I wouldn't recommend that you take look due to the presence of extremely high voltage in that area. Hope this be of some help. pls post again how things turn up. kind regards.
May 20, 2007 | Hansol Multitech 920p 19" CRT Monitor
Hansol 920 A 19 in.CRT Conventional Monitor Logo
35 people viewed this question
Top Hansol Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
