Question about Toshiba TZ43V61 43" Rear Projection Television
The bottom 6in. is black no picture
Its a 1999 toshiba tz43v61 it just lost the bottom of the screen. it is very dusty in side
I cleaned the dust, then tapped on the two little black boxes that have like a sparkplug wire going to the tv tube its been 3 weeks and still works fine.
Posted on Oct 24, 2009
While wacthing tv there was a sugre and i lost power due to lighting. i turn my tv back on and all iget is a black sreen. i try to reset every thing no go
Replace the deflection board thats the number one item that is likliest to have the issue with those symptoms.You can get a replacement deflection board from www.tvcircuitboards.com
Jul 26, 2011 | Toshiba TZ43V61 43" Rear Projection...
My blank screen, red flashing light projection tv
Most likely the lamp has failed. The red light will blink with a pattern (number of flashes then a pause) You can refer to the users manual for information as to the nature of the problem by the aforementioned pattern.
Cheers
Jan 15, 2010 | Toshiba TZ43V61 43" Rear Projection...
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall socket.my power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
Toshiba TZ43V61 43 in. Rear Projection... Problem
Try unplugging unit for 5 minutes, then plug in and turn on. If this works, your power supply may be going. However it is more likely that the bulb is gone, you can replace it yourself, but make sure you get the right bulb for that unit and take care in the installation of it.Go to the manufacturers website and look up your model and find out how to inspect and remove the bulb.
Bulbs can run for 140 to $300 and can be found on EBAY
Sep 28, 2008 | Toshiba TZ43V61 43" Rear Projection...
Toshiab tz43v61 power light blinking
I had the same thing happen to me 3 times and the first time it was 2 months off of warranty. It is costing me $395.00 each time, the TV is only 7 years old. Lets see I paid $2400.00 for the TV and also have another $1185.00 into it for repairs, and it is doing the same thing again. My suggestion would be NEVER buy another Toshiba product. I find it interesting that their website says "As a proven technology leader, Toshiba is committed to the goal of ensuring that, to every customer, the Toshiba name remains synonymous with lasting quality, durability, and value." WHAT A LOAD OF ****!!!
Nov 22, 2007 | Toshiba TZ43V61 43" Rear Projection...
No picture
95% 0f the time when this happens to a toshiba projection or regular set, the power regulator IC is bad. It is a componet that should be replaced by a service technician as there are too many points inside this set that can zap you and hurt you. If thats the only problem your talking in the range of 175 to 250 to repair this set. Good Luck
Jul 31, 2006 | Toshiba TZ43V61 43" Rear Projection...
Toshiba TZ43V61 43" Rear Projection Television Logo
78 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
