Question about Kitchen Ranges
THE RIGHT FRONT BURNER APPEARS TO HAVE COME LOOSE
ON MY MAYTAG OVEN, MODEL # PGR571BDW, THE RIGHT FRONT BURNER APPEARS TO HAVE COME LOOSE. WHAT WILL IT TAKE TO FIX IT?
    President:
  • 1,304 Answers
You masy be able to just turn it slightly to tighten up
these are pressure twists
Posted on Oct 06, 2009
I have a Maytag self cleaning gas range. It says super capacity plus. I cannot find a number on it but I know it is several years old. The oven control is digital and mounted on the top front of the...
That piece that glows (the ignitor) is weak and needs to be replaced ,to order that part you need the model nuber and a lot of times it is on a label inside of the storage drawer area
Jul 23, 2011 | Maytag Kitchen Ranges
This concerns my gas range, a Maytag Model # PGR5710BDW, a burner
its been a long time since ive seen this model but memory serves me this way
you will need to take off all four burners to get access under the top
but before you go to that extreme try turning the burner and pullin up, you should find a spot that releases it , clean underneath in and replace it
you should be able to spin it back into place
you can use an oil can wrench to spin it to lock
but make sure you put something soft on the bar of the wrench as to not chip the burner
Oct 04, 2009 | Kitchen Ranges
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
No spark to ignite stoves
Igniter will need to be replaced. You can go to repairclinic.com and type in your make and model and you will find it there!
Aug 18, 2009 | Maytag MGS5770 Gas Kitchen Range
I meant to push broil, but pushed clean and my food is locked inside. How do you cancel the clean?
Look at following areas for the model number
  • Under Right Front Burner
  • Under Left Top Burner Front Or Rear
  • Under Main Top Left, Rear Or Center Front
  • Under Left Rear Or Right Front Element
  • On Nameplate Inside Burner Box
  • On Front On Burner Box Bottom
  • On Nameplate On Oven Door Liner
  • On Main Front Behind Oven Or Compartment Door
  • On Front, Center Bottom Of Burner Box
  • On Thermostat Cover Under Main Top
  • Get me the model ,number for your oven and I will be able to help you better, Thanks, Sea Breeze
Mar 29, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Need Manual For Electrolux Oven Model EOB 985GR
Having trouble locating the correct model number. Look at following areas for the model number
  • Let me know, Sea Breeze
Mar 27, 2009 | Electrolux Ovens
Oven is not heating properly
Could you find the completer mode number because the number listed above your post is for a gas oven.
  • Thank You, Sea Breeze
Mar 25, 2009 | DCS RGS-484GG Gas Kitchen Range
GE Elec Range - front left burner will not turn on
If you have the glass cooktop slide-in model, the problem is most likely the burner "ribbon' under the glass top for the small burner has come loose. I fixed mine with only a phillips-head screwdriver, needle-nosed pliers, and a 1/4" wrench (1/4" socket on the end of a nutdriver works better). Here are the steps I took to fix it: 1) Slide the oven out from the counter so the sides of the oven are clear of the counter top. 2) Remove the phillips head screws-1 on each side of the oven near the top/rear. These will be the only phillips-head screws you will need to remove. 3) Open the oven door and remove the 4 hex-head screws at the top/front/inside the oven- there are 2 on each side which follow the opening of the door. Then close the door. 4) Pull off the burner knobs by gripping them and pulling straight up. Don't worry, you will not break them but you will need to give them a good tug. 5) Remove the burner retaining nuts that are under the knobs-you may need a wrench to loosen them but only tighten them by hand when reinstalling. 6) Pull the face of the control panel away from the oven slowly until you see a ribbon connector on the right side and then disconnect the ribbon and remove the face plate from the oven. 7) Remove the 4 hex-head screws from the face plate bracket (the plastic part that was holding the face plate) and pull the bracket toward the front of the oven until it flops over and rests on the oven door handle. 8) remove the 2 black screws holding down the glass top-one on each side of the oven-the screw heads face the front of the oven. 9) Disconnect the two wiring harnesses attached to the cook top. Don't worry, they only fit one way so you don't need to label them. 10) Lift the cook top until the wiring harnesses are clear of the holes and place it upside down on a flat surrface. 11) Remove the two retaining bracket screws and brackets from each side of the non-working burner. 12) Slowly lift the burner and flip it upwards until you see the ribbon coils. It should not be necessary to disconnect any wires. 13) Look at the ribbon coils very carefully to see if any of them are disconnected from their main connection points. If so, feed the ribbon back inside the pinch point (you may need a small screwdriver to open the pinch point first) and then use a pair of needle-nosed pliers to pinch the ribbon to hold it in place. I had to use a voltage meter set in the OHM position to find where mine were disconnected. Once you pinch the ribbon end back into place, put everything back together in reverse order. If your burner still does not work, your burner knob switch may be bad. I hope this helps. Good Luck!
Dec 26, 2008 | GE Profile JB968SHSS Electric Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
