Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Icemaker not working and water draining into refrigerator. Help!
    President:
  • 1,304 Answers
Your fill tube is out of place
look at the back of the unit there is a small tube that fills the ice machine it is probably out of the hole you can force it back in if your strong enough
Posted on Oct 03, 2009
guly
  • 67 Answers
SOURCE: icemaker does not work
check the water hose. water supply to ice maker
Posted on Sep 24, 2007
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 106.78202890 Ref. Icemaker seems
Hi there, I believe you may have a defrost drain problem. See the water has to drain somewhere else when the drain is stopped up. So instead of into the catch basin on the bottom of the frig it cascades down the backside of the frig and ends up under the crispers. To fix the problem you must clear the defrost drain. It is located beneith the evaporator coils. When the frost on those coils melt it turns to water. Remove the freezer access panel, and clean out the drain. Use some hot water or a shop vac.
Posted on Jan 12, 2009
ginko
  • 19396 Answers
SOURCE: Icemaker dosn't work no water going to icemaker but have drinking
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
shinn8
  • 85 Answers
SOURCE: Whirlpool ET21DMXDW05 top freezer. icemaker not working
Give it some more time. The icemaker has an internal thermostat and it will not come back on until it reaches 16 degrees. It takes a while after it gets warm. if it doesn't start functioning in a few more hours you may have other problems. Hope this helps
Posted on Jun 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: uhhhhhh
There could several reasons for the water under refrigerator. Leaking water connection to water control valves. leaking defrost condensate pan or blocked condensate drain beginning inside freezer rear wall cause by ice or other gunk caught in the defrost drain line. Because leaks always happen differently on every model I will give you a page to look over and watch a small clip about fixing a refrigerator leak. One moment as I retrieve the information and links. Sea Breeze
Posted on Dec 22, 2009
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Leaking water
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 10, 2010 | Amana ABB2224D Bottom Freezer Refrigerator
Whirlpool gold refrigerator leaking under neath on the side
If its leaking all the time you could have a problem with the water supply line (if it has an icemaker)Or the solenoid valve (water valve) that opens to refill the icemaker after it drops (harvests) the ice.Or the plastic water lines that run from the valve up to the icemaker.You should pull the frig out from the wall and check the back for leaks.You could also Just shut off the water supply to the unit and see if it stops.These leeks cause a lot of damage when they go unnoticed for a long time.I would check it out asap.
Jun 03, 2010 | Whirlpool ET1MHKXM Top Freezer...
Roper refrigerator leaks
Good job! most people do not know about the evaporator drain.
I would check the tubing to the icemaker, icemaker inflow valve and, water filter.
Jan 23, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Makes ice but is very slow to dispense and makes a load bumping noise
Turn off the water to the icemaker. Locate the plug from the icemaker to the freezer & disconnect it. There is usually 2 screws under the icemaker that mounts it to the freezer, remove them. Some may have a screw or 2 in the top also. these are only short sheetmetal screws. You should then be able to extract the icemaker, a short hose attatched to the icemaker will come out of the back of the freezer. When complete the freezer/frig will work fine. Thaw out the icemaker, drain the water out, inspect the rotating finger grate area for any objects. Shaking it upside down may help. Reinstall & test, if it doesn't work it is bad. You can take it to an appliance repair store to replace.
Nov 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Our kenmore side by side is leaking water into the bottom of the freezer how do I find where it is coming from and repair?
Most of the time that problem is caused by your drain hole in the freezer being blocked up with food or trash....or sometimes ice. Every 8, 10, or 12 hours depending on your defrost timer you fridge will defrost itself and drain the water under the fridge to a pan. If that drain is plugged then the water runs into the bottom of the freezer and sometimes will leak out onto the floor of your house. Another thing that it could be is the icemaker. Make sure the icemaker is not spilling water all over. If your icemaker is working ok, and there is not icecicles all over then rule out the icemaker. I would bet it's your drain.
Sep 11, 2009 | Refrigerators
Jun 07, 2009 | Refrigerators
Water in refrigerator, freezer is cold refrigerator is not
sounds like you have a frozen defrost drain. This is a fairly easy repair you can do yourself.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peyton
Mar 11, 2009 | Kenmore Refrigerators
Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
Dec 07, 2008 | Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
50 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
