Question about Yamaha RX-V2600 Receiver
My yamaha rx-v2200 receiver power shuts off in about 5 sec after turning the unit on. why and how to repair
5 Suggested Answers
  • 7 Answers
SOURCE: Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Posted on Jun 05, 2007
SOURCE: Yamaha RX-V2400
Get another receiver! I had the same problem and had the power supply replaced $250 and after 3 months it started doing the same thing.  I just purchased a Pinoeer Elite VSX 90TXV.
Posted on Oct 17, 2007
simplemitch
  • 752 Answers
SOURCE: Yamaha RX-V1 Power
The amp is blown. Unhook all speakers and try it again. If it still shuts down it will have to be repaired.
Posted on Nov 29, 2007
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
Yamaha RX-V595 receiver won't stay on
check ur speaker wires, try disconnect all wires from back of unit and then try to turn on unit .
if it stays on whit no wires attached than u have short connection at speaker wires .
if doesn`t come on then try to fasten screws at back of the unit ,
may sound like BS but if amp board don`t have good ground connection it can go in protection mode happened to me on RX-V592
Dec 23, 2012 | Yamaha RX-V595 Receiver
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
I have a yamaha, natural Sound Av receiver RX-V483, every time that i start the unit it will shut down after 5 seconds. thank you very much
It indicates an output load problem, dis-connect the speaker wires from the back of receiver. Next power on and turn the volume right down, if the unit runs, check for shorts in the speaker wires and speakers. But if it still shuts down "with speakers and wires dis-connected" one or more of the audio output ic's is shorted and will need a professional to assess the item.
Feb 02, 2011 | Yamaha RX-V463 Receiver
Re: Yamaha RX V670 Receiver Powering Off
I have found there are capacitors failing through the output circuit. Look for 10, 33, 47, etc.. microfarads.In that range. I charge typicaly 150 to $200 with parts on something like this. Larry's Electronics ledstiles@hotmail.com
Apr 23, 2010 | Audio Players & Recorders
I can't get my cable remote to work with my RX-V2200. Are the new universal remotes going to have the same problem?
You need a remote control that can send "Discrete" commands. One for "on" one for "off". "PC programmable" or "learning" remotes will do the trick. "Universal Remote Control" or "Harmony/Logitech" are a couple that have many to choose from. Prices range from 80 to 1,000.00 depends on what you want it to do. If you need some more help, post a comment and I will be glad to help you further.
Sep 23, 2009 | Yamaha RX-V2200 Receiver
My Yamaha RX-V470 Kicks off after a couple of SEC.
Two possible problems , bad memory back up cap or weak voltage regulator.
Jul 10, 2009 | Yamaha RX-V995 Receiver
Yamaha RV-V2200 without power loses settings under 24 hours
It could be a battery, a bit like the type you get in watches. But I reckon it's a memory retention capacitor that has failed. These are small looking things that look like electrolytic capacitors that have been squashed from above. They appear to have a working voltage of around 5.5 volts too. I am enclosing a picture of one, though it could vary in style. You might find it near the main display of the unit.
Apr 30, 2017 | Yamaha RX-V2200 Receiver
Rx-V2400 Shut Down
Hi Seems like you have a shorted output channel, remove all your speaker connections and try again, if the problem persist, good chances are that you need to replace a couple of power transistors, let me know if you need more help, I've fixed some Yamaha amplifiers with this problem Good Luck Miguel
Oct 06, 2007 | Yamaha RX-V2400 Receiver
Yamaha RX-V2400
Jun 04, 2007 | Yamaha RX-V2600 Receiver
Yamaha RX-V2600 Receiver Logo
144 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
