Toploader washer fills with water then trips
Frigidaire toploader washer fills with water then trips circuit breaker.
    Genius:
  • Washing Mach... Master
  • 1,461 Answers
Could be @ the point the heater comes on indicating faulty element, or Motor start indicating motor fault try on other functions to find out which
Posted on Oct 03, 2009
Washer wont fill with water when i pull button out
Is the water on to the washer? Is it plugged in? Check the house circuit breaker box and see if one of them tripped to the washer.
Jul 08, 2016 | Washing Machines
Microwave tripping breaker
The microwave may be too big for the circuit it's on. The breaker is tripping to protect the circuit. Try to determine how many appliances/lights/etc are running on this circuit. If there are alot of things, you may try turning some of them off when trying the microwave. If not, then you may have an electrical issue in the wiring or the breaker.
NEVER replace a breaker/fuse with anything larger than what's already in there (recommended by code or a manufacturer).
Feb 15, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Maytag Neptune Tripping circuit breaker midcycle
this looks like it may be your wash heater or your motor
if you take off your motor lead from motor if it still trips ???????? then look at the heater it wants to be replaced
Nov 22, 2013 | Maytag Neptune Washer Door Mah3000aww
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
Washer filled up but will not agitate or
Does the motor run? May be a tripped circuit breaker on the motor. If motor runs, may be a broken belt.
Jul 27, 2009 | Washing Machines
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Amana washer won't fill with water
1st I checked the power, compressor in garage had tripped the breaker to the washer circuit. This model has no bells or whistles to tell you if the power is on to the unit. Reset the breaker and unit works.
Thanks FixYa
Dec 22, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washer trips circuit breaker
Is washer relatively new? Check circuit breaker for proper size (20 AMPS). Washer must also be on its own circuit. It appears that when the motor starts up it is causing a spike in current (as with any motor), so the breaker is either undersized (Note that if breaker is undersized and you up it to the next size you would also need to replace the wire with the next size up which would be 12/2 with ground), or if you have had your washer a while which I believe is your case the circuit breaker is weakening and is tripping on the current spike. Try swapping out your circuit breaker with a new one and try running the washer again.
Sep 04, 2006 | Maytag LAT2600A Top Load Washer
Washing Machines Logo
108 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
