Question about Moen & Villeta Two Handle Lavatory Faucet
How do you take a moen bathroom Model #: 84206 apart to fix a drip? Hot water side has a slow drip. Need to replace a seal. How does it come apart?
  • 129 Answers
On the handle it self you should see a red and blue button plug. Remove this and you will see set screw. Remove handle, remember to shut off hot and cold water supplies under sink before you go any further.
Posted on Oct 04, 2009
Fix eurostream bathroom faucet model# GYE370140
The stem may have to be replaced. Normally, there should be packing or a seal to prevent the drip.
Jun 19, 2017 | Plumbing
I just had a plumber install new moen faucets in my bathroom sink. After he left, I discovered that there is a slow drip. These faucets are brand new! What could be wrong?
well it can only be 1 of 3 things, 1st can you tell if it is hot or cold water dripping?? 2nd is the handle loose can you wiggle them and 3rd how old is the faucet I know you said it is ''New" but it could be "old" stock from his shelf in which case the gaskets/O-rings could be dried out and needs to be replaced...
if loose then on top where the "c" or "H" is that cap comes off using a finger nail or small knife point pop off caps under caps there is a screw remove it but first turn off water under sink you will a bigger nut use a adjustable wrench to snug it more then try again if still leaking remove that big nut the is a washer on the bottom that will be leaking there are many sizes so you will have to buy an assortment with mixed sizes fond the two you need remove screw on bottom put new one in,,, put it all back together...
ps if you have vinger you can soak old washer but this only short term fix, replace washer
May 13, 2017 | Moen Plumbing
How to fix drip on Moen T951 faucet
Replace cartridge..Moen will give you free cartridges for life of faucet.
Sep 09, 2014 | Moen T951 Monticello Two-Handle Low Arc...
How do I adjust the volume or pressure on the hot water in my moen bathroom faucet?
Is it single lever ? If so you can try adjusting ant scald stop under handle. Always shut off water before working on plumbing.
May 02, 2014 | Kitchen Ranges
Moen 2 handle bathroom sink faucet, ca84004 series. cold faucet functions fine. hot faucet does not shut off. handle turns as cold does but hot does nothing. water must be shut off from wall supply...
Try going to their web site and selecting consumer support. Usually the bathroom sink faucets, you can unscrew the handle with a Phillips screw-driver and then twist the body of the faucet off. Then there will be a nut to screw off, to remove the inner "guts". It sounds like the rubber seal is worn out on the inner faucet assembly. If so, then all you would have to do, is to replace the rubber seal. I hope that this helps you out. If not, then I would contact the company and see about a replacement faucet, depending on your warranty! If worse comes to worse, then I would call in a professional plumber, to assist in fixing it! Good luck my friend.
Jul 06, 2011 | Moen Plumbing
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
Moen single-handle kitchen faucet only drips on the hot side. Removed cartridge and cleaned out some foreign particles. Replaced and still drips on hot side, not cold side?
have to replace the cartridge..hot water softens rubber and causes it to leak first...check the left side port on valve to make sure no burrs or bites in metal eating away at cartridge seal...
Nov 21, 2010 | Moen & Replacement Cartridge
Reinstalling a handle on an older Moen 84206
Here is the owners manual for your faucet that will guide you through putting the handle back on. Good luck!
http://www.moen.com/shared/pdf/instruction_sheets/INS060B.pdf
Apr 06, 2009 | Plumbing
Moen & Villeta Two Handle Lavatory Faucet  Logo
537 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
