Question about Whirlpool LGR3624JQ Gas Dryer
Ignitor does not glow
I have a whirlpool gas dryer that doesn't heat. I replaced the ignitor and the sensor and the ignitor still won't glow. I checked out the part and it reads 48 ohms.
  • tgood93728 Oct 03, 2009
    I bought a brand new ignitor but maybe it is defective, I will check it out. Thank you.
    President:
  • 1,304 Answers
The flame sensor rarely goes bad
if the ignitor is not glowing
then thats the problem
take an amp reading it shoud be between
2.7 and 3.6 out of that range it will not glow
if your not getting a reading you need to chase your voltage l1 is you most likely culprit
Posted on Oct 03, 2009
Testimonial: "Thanks"
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
Whirlpool dryer(LGQ9557HQ0), ignitor ignites but flame does not light
mounted on top of the gas vavlve is black electrical coils when energized it opens the gas valve,if one of the coils are defective it wont open and let the gas thru,its hard to test the coils so most repairmen just replace them all
Jul 07, 2008 | Whirlpool Dryers
No heat coming from dryer
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 30, 2009 | Whirlpool Dryers
Why wont my dryer heat up
Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat2.gif or the auto sensor is not working correctly.
Nov 26, 2009 | Whirlpool LGB6300 Gas Dryer
The dryer does not heat
Nov 19, 2009 | Whirlpool Dryers
I have a whirlpool dryer.... the blower works fine but will not heat up any suggestions
Nov 12, 2009 | LG DLE0332 Gas Dryer
My whirlpool dryer wont heat up
Oct 27, 2009 | Dryers
My dryr tumbles but does not dry
Gas dryer? First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Electric dryer? Temperature sensor has failed or heating element has burned out.
May 30, 2009 | Whirlpool Dryers
There is no heat being produced
HI, Remove the front lower panel. Start the dryer and see if the ignitor glows. If it glows but the gas valve does not open, Change the coils on top of the gas valve.
If the ignitor does not glow, test the ignitor for 120V. If there is voltage to the ignitor but no glow, change the ignitor.
If there is no viltage to the ignitor, check continuity on the thermostats and the fuse that are located on the blower housing. Also test the sensor located on the burner.
I hope this helps. Please let me know if I can assist you further.
Vic
May 24, 2009 | Dryers
Whirlpool gas dryer model number ler7646eq2 does not produce heat
Need more info. Does it rotate? If it has a viewing door on the front, you may see if the ignitor is glowing. If the ignitor glows, the ignitor (flame) sensor may be bad, and the ignitor will shut down.
Aug 09, 2008 | Whirlpool Dryers
Whirlpool LGR3624JQ Gas Dryer Logo
698 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
