Question about Dryers
My dryer starts to squeak really loud when we run it then about 5 minutes in to the cycle it stops can you tell me if I can fix it
    Genius:
  • 1,461 Answers
Yip .Sounds like jockey pulley worn, give it a clean and lightly oil
Posted on Oct 03, 2009
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer drum has an intermittent squeak when running
there is a belt tension'er it might need to be replacing or temp fix greasing or drum bearing replacing or temp fix greasing to do this you will have to remove the drum
May 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Dryer makes squeeking sound when running
you need to replace the rollers an idler an belt,,,this will stop your noises...call if need help...
May 10, 2010 | Dryers
I have an Amana (M# ALE643RBW), when started the dryer squeaks for the first 10 minutes of the cycle, then slows to a squeak every 7 minutes... why? Maybe a bit of lube?
I have the same problem. While I have not fixed it yet, I assume it is a drum roller. Most dryers have two 4 to 5 inch diameter drum rollers which hold up the dryer barrel in the back. These drum rollers are wheels which have rubber on the outside where they touch the drum and a metal hole in their middle. They turn on a metal rod which goes through their middle. As the inside of the wheel turns on the rod, the metal gets eaten away and they squeak. Replacing one or both drum rollers should fix the problem.
Nov 25, 2009 | Amana Dryers
Makes squeaking noise after running for about 10 minutes
Replace the dryer drive belt and the dryer tub rollers.
Mar 01, 2017 | Kenmore Dryers
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
2 year old Kenmore Elite Front Load Dryer makes loud squeaking
We can fix this. your dryer has some wheels/rollers and an idler pulley they get worn and or plug up with fabric sheet guu.what you do is pop the top,that the frount off and this will expose the drum,undo the belt the clean inspect /oil and replace worn parts.sounds like you wont see much wear because it stops after[gets warm]so may get buy with oil/cleaning Ps unplug before working
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
there are 2 drum rollers at the back of the dryer. shut off power, pull drum and you will see 2 rubber wheels. there is a little plastis triangle that keeps the roller in place. try spinning the rollers . they probably will not spin too freely. remove triangles ,inspect inside of roller the stainless steel bearing may have gunk on it try to clean off . also check shaft roller rides likewise remove any debri use a little rubbing alcohol to remove gunk. also check the idler roller that routes the belt for the same things. good luck
Nov 16, 2008 | Kenmore 67082 Electric Dryer
GE DBXR463GB Gas Dryer is squeaking loudly when it runs
one of 2 things can be wrong. Back bearing if bad will sound like a bird chirpping, front bearing glide will be more constant squeek. both need to be fixed by experienced tech.
Jan 05, 2008 | Dryers
Dryers Logo
56 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
