Question about Mitsubishi WS-55859 55" Rear Projection Television
I have an orange wavey line in the top of the picture and words are double and two different colors.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
WS-55859 uses a single STK-393-110 convergence IC--if convergence is out and will not adjust--the IC and any resistors around it (that are bad) need to be replaced and the set adjusted.
This is very common---I have repaired hundreds of these sets---you have two choices---If you can do the repair yourself you can buy the chip on Ebay for about 14 dollars plus shipping. I have detailed instructions for this repair but I am not permitted to post MY email here.
If you cannot do this repair yourself--shop around your area---most shops charge 300-400 for this repair----if they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
I have done hundreds of these sets and here I charge 200-250 total in the customer's home......
If you have any questions or need advice reply to this posting here and I will assist you. You can search here for all my posts concerning this type of repair on sets just like yours---
Regards, SD TECH
Posted on Oct 03, 2009
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
I have a Mitsubishi WS-65869 65 in. Rear Projection Television and it has created a wavey line and has distorted the image. i have a picture of it i can send. Any help. i can send pictures of screen.
If you see separation of colors (red, green) in this wavey line most likely you have problem with convergence circuit. Two convergence amps have to be replaced. They located in a middle of the TV boards attached to big aluminum radiator and they part number starts with letters "STK".
I would recommend to let professional with this repair. Should cost you about $250-$300.
Regards.
Russ.
Dec 01, 2010 | Mitsubishi WS-65869 65" Rear Projection...
I SEE DOUBLE THE PICTURE AT THE TOP LEFT IS WAVEY
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 28, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Component 1 has wavey lines all other conections
For component 1 on the tv I just changed from 1080i to 480i on the Verizon Fios set top box and that corrected the problem...
Aug 29, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Wavey line and double image
Your TV most likely has a problem in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 19, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Double picture & color problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Wavey lines
Sounds like your set has dried caps in the Power Supply, take it to a decent tech, its not something you should try to do yourself as dangerous voltages can still be present evn if the set is unplugged.
Jul 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
