Question about Westinghouse Televison & Video
I have a flat screen tv model 32701 purchased 5 years ago. It is cable connected. I am reciving audio output but NO video output Bill Nakos bnakos1@comcast.net
5 Suggested Answers
skotkolr
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
Coldcut
  • 1554 Answers
SOURCE: lg plasma
there are 2 types of flicker, one is the lamps that drive the display and the second is the sync signal of the video.
I assume the video sync is the flicker you see,
I would try connecting a different way to make sure it is not the tv,
connect using the aux /rca connectors to cable box.
and or connect using the cable direct bypassing the cable box.
I have seen several complaints about the hdmi cable signal being incorrect in some way,
this is the same issue that the svideo connector had in its early adoption signal was too hot or too low.
another thing to watch out for is the low light sensor on the front of tv if it gets an incorrect reading it can flicker the back light though it should be slow in doing so.
some times the flicker you see is not flicker but ac running through the sides of the picture from an ungrounded cable source.
how does it perform if you play a dvd player , with and without the cable box connected.
Posted on Apr 29, 2008
budmrtn
  • 11361 Answers
SOURCE: The *audio cuts out occasionally on my 42 INCH
Try using the Audio line out RCA jacks feeding a PC powered speakers to see if it does the same thing, If it is OK, then the problem will be in the power amp sections that drive the speakers.
Posted on Oct 30, 2009
How to connect my hdtv to surround for audio
It looks like from my searching you have an optical link on your tv and your reciver. You should just have to choose that as your output on the tv and your input on the reciver. It should be labled something like spdif. In my opinion it is the best cable ever until hdmi came out now its still really good.
Jan 05, 2017 | Panasonic Audio Players & Recorders
IPod player won't show on screen of my Sharp LCD LC-46D62U
Hello !
Guess the the cables are not proper connected or cables might have some problem ... or the ipod is not supporting to ur TV output ... first u try out with other Tv and confirm ...
Dec 10, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
BOUGHT NEW FLAT SCREEN NEED HELP HOOKINF UP DVD/VCR
1. Video Output from DVD .. and Video Input in the TV..Used your Yellow cable for Video Output... 2. Audio Output from DVD and Audio Input in DVD (if your TV have a built-in Speaker)
Red & White Cable for Audio Output..
If your DVD has its on Speaker... don't follow the step 2.
if no sound.. please see to it if your speaker of your dvd is connected.. (if not Please connect it)
Aug 19, 2011 | Televison & Video
5 want to connect my 35 inch flat screen tv to my laptop what cables do I need?
Depending on which model laptop you have, there should be an HDMI output port. Similarly, your tv should also have an HDMI input jack. What you need to purchase is an HDMI cable and you will be able to hook up you laptop to your tv. Depending upon the model tv you have, it should also have a vga video port similar to one on your laptop. If that's the case, you'll just need a standard VGA cable.
Jan 25, 2011 | Computers & Internet
I have just bought the samsung ht c555 home cinema kit connected it to the the tv all is working well when playing a5.1 dvd but ihave no sound out of the system when on ordinary tv how do you get all 5...
you will have to connect an audio output from the tv to the sourround reciver. you should have some audio output on the back of the tv and a corresponding input on the samsung ht c555
Dec 24, 2010 | Samsung Audio Players & Recorders
Can I hook up my Model TR 6030 to my Samsung TV?
I can't find a match for the model. What brand is it?
Generally, any modern all-in-one will interface with any modern TV. It all depends on the connections matching up. Keep in mind that the system is for the audio and source origination while the TV is there to add a visual, not audible, aspect to your enjoyment. If there is something the TV can display it probably originates from somewhere that could connect directly to the audio system, so let the specialized audio equipment handle the audio while the TV handles the video.
The TV probably has HDMI, component and/or composite video connections. Use whatever Video output matches on your all-in-one, in that order of preference and decreasing video quality.
For TV-based listening (that usually means 'cable), use the audio output of the cable box primarily in the following order of preference: HDMI, optical or coaxial digital, analog (RCA). Without brand/model specifics, I can't guess what that would entail.
Jan 31, 2010 | Audio Players & Recorders
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Can't get audio via optical port.
ok, i think the problem lies with the tv, there must be a setting in the sound menu to use optical as sound out, as the sound will be via the HDMI cable, i applogise if you have checked this.
Sep 09, 2008 | Sony BRAVIA KDL-40V3000 Television
Sanyo tv
cable bos is a scientific atlanta
Mar 18, 2007 | Sanyo PDP-42H2A 42 in. Plasma Television
Televison & Video Logo
595 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
