Question about Epson Stylus Photo R1800 InkJet Printer
I have lost the power cable to my R1800 do you know where I can find another Thank you
Epson R1800 won't start up
Unplug the power cable from printer while the printer is powered on.
Press and hold OK and HELP buttons while plugging in the power cord.
Wait for the screen to go black or blank before releasing the keys.
Just turn on the printer and configure your printer new
If you need any technical help on printer then you can reach at here
Mar 06, 2013 | Epson Stylus Photo R1800 InkJet Printer
Tip
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Drivers and software download areas for brands listed below, just click to gain access and then locate driver for your needs.
Brother Epson Sharp Canon Lexmark OKI Dell HP Kyocera Samsung Konica/Minolta Xerox Panasonic
PLEASE NOTE
When installing drivers / software it is generally a good practice to -
  • Delete old/previous installs
  • Leave printers USB cable disconnected from computer until newly installed software requests it to be connected.
Happy Printing
Soulvisitor.
on Apr 12, 2009 | Epson Stylus Photo R1800 InkJet Printer
No power. We had power outages. Is there a fuse inside? thanks... Greg
Check that the Fuse F1 on the Power Supply Board has not blown.
jackpot00_106.jpg Download this service manual for Epson Stylus Photo R1800 ..>
http://www.resetters.ru/download/SM/R_1800_2400_B.pdf Go to page #206 .
Note:Note: Epson manuals are provided in .PDF format, which requires the free Adobe Acrobat Reader. If you wish to save the .PDF file to your computer for later use, right click over the link and choose "Save Link As" or "Save Target As.")
Jul 26, 2011 | Epson Stylus Photo R1800 InkJet Printer
R1800 Won't Power Up
Just check the power cord of your printer it maybe don't have any lost connection or change the power cord. If did not work also their was a problem of your powersupply. You need to bring it to the electronic center technician for the proper repair of the power supply.
May 26, 2010 | Epson Stylus Photo R1800 InkJet Printer
Please let me know how to scan a document with Epson printer c8400 as I lost my user manual
Insert your doc. into the scanner and click on the Epson Scan icon on your desktop. If you don't have that shortcut go to start menu, all programs, click on Epson Scan and then click again on Epson Scan.
Oct 08, 2009 | Epson Office Equipment & Supplies
Anyone know how to fix banding in dark areas of photographs?
I see your problem. You need smap and eject adjusment (PF adjusment), using R1800 adjsument program. Try to find at indoreset.blogspot.com
Jun 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Electrical
The printhead may have lost it's connection to one of the flat ribbon cables that normally goes into the back where a small circuit board and sensor read the printhead's location.
The cable is brown, very thin & wide and needs to be pushed carefully back into the receiver to get a connection.
This is just a guess but it's a similar behaviour to the C86 which did this when my CIS knocked the ribbon cable out of position and the printhead became "lost" or "blind".
Hope that helps.
Mar 07, 2009 | Epson Stylus Photo R1800 InkJet Printer
Dead R1800
There is no solution to this issue other than service or replacement. If in warranty I would contact Epson tech support directly.
Aug 12, 2007 | Epson Stylus Photo R1800 InkJet Printer
My Epson R1800 keeps resetting itself
You have done all the usuall checks, but you may have a usb power problem, try the printer without any other usb peripheral in and see if it stays connected. If not, then the usb connection or workings in the printer may be faulty and keeps disconecting, hence the bing bong as it re connects to windows. You may have faulty hardware, leave the printer disconnected from usb and mains for 15 mins or so then try again.
Mar 18, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
14 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
