Key lock on my lg tv
Ok the buttons on the tv are locked and i cant get to the menu so i cant program the tv and i because of that i dont have all the channels the make is a lg du -27fb34c
  • 325 Answers
Sounds like its been put into Hotel Mode. This is a mode normally found on Tv sets that are installed into Hotels Hense the Name this Greys out a lot of the tuning option on the Tv.
Give this ago and see if this will sort you out. Before I go any further be very Carefull in this menu as this is the hidden LG installer menu and I do not want you to brick you telly.
Hold down the menu button on the remote for Approx 5 seconds then type in 1105 This should bring up the hidden installer menu so that you can check that the Hotel mode is not set to on. Make sure this is set to off as This may be the cause of your problem.
Hope this helps you sort out your Telly. If so then please leave a thumbs up.
Cheers Little Dish Fitter
Posted on Oct 03, 2009
  • demolishionc Sep 21, 2011
    Ok, i found out how to get it out of hotel mode just now, no code will work at all so i poped out the cable/data card on the back and moved the jumper over and now i have access to everything. im not sure if its just a cmos reset or a unlock but it works.
  • Tom Sanders
    Tom Sanders Oct 04, 2012
    Can you be a little more specific on what jumper you moved?
KEY LOCK ON
Key lock applies only on manual buttons on tv set try with another remote and go to menu and change the setting of key lock from on to off
Jul 15, 2014 | LG 42LG30 42 in. LCD HDTV
Key lock off on lg ps3000 tv
Hi, here are the instructions for resetting your tv. on your remote press menu..then "option" hit "ok" on remote, then scroll down to "factory reset" hit "ok" on remote again, select "yes" on screen and hit "ok" on remote again to begin the reset. If your system is locked and it asks for a password when entering the menu punch in 7,7,7,7 on the remote to gain access to the menu. hope this helps you!
Jun 10, 2012 | LG 50PS60 50 in. Plasma HDTV
Key on lock on the screen how fixed
Hello
Go to page [99] of it user manaul. You can see adjustments to make key lock OFF.
Jan 20, 2012 | LG 50PS60 50 in. Plasma HDTV
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
Cant turn on set and remote wont work, how can I reset tv and remote to work after our grandchildren locked the fromt buttons ans remote?
hello it sound like the key lock has been activated
The TV can be set up so that it can only be operated with
the remote control.
This feature can be used to prevent unauthorized viewing.
This TV is programmed to remember which option it was
last set to even if you turn the TV off.
Press the MENU button on the remote
control, then use the UP/DOWN arrow
button to select the Special menu.
Press the RIGHT arrow button to activate
the Special menu.
Use the UP/DOWN arrow button to
choose Key lock, then press the RIGHT
arrow button.
Use the UP/DOWN arrow button to select
On or Off.
Press EXIT button to save and return to
TV viewing or press the MENU button to
save and return to the previous menu.
the remote control.
Language
Main Source
PIP Source
Captions
Caption/Text
ARC
Key lock G
Auto Convergence
Auto Move
F Back Next G
SETUP
VIIDEO
AUDIIO
TIIME
LOCK
SPECIIAL
On
Off
With the KEY LOCK ON, the display
'KEY LOCK' appears on the screen if
any button on the front panel is
pressed while viewing the TV.
which option it was last set to
even if you turn the TV off. good luck
regards
shaun
Dec 12, 2010 | Zenith R56W36 56" Rear Projection...
I need to reset a LG rumor touch to factory settings. Forgot lock code. Is not last four of phone # or 0000. Is there a programming code to re set it?
If you have forgot the codes for your mobile you can unlock it by using the last four digits of your phone number or four zeros. If these codes are not working you can contact your network service provider to get the unlock codes.
If you need to reset your mobile then press the "Menu" button,from main menu scroll to "Settings/Tools" and select the option by pressing the center "Menu/OK" button.Scroll to "Settings" and select.Scroll and select "More". Scroll to "Security" and press your "Menu/OK" button.Enter in your phone's security code when prompted. Select "Reset/Erase", then "Reset". A warning message will appear. Press the "Menu/OK" button, then highlight and select "Yes" to confirm the reset.
Thank you !!
Jun 10, 2010 | LG RUMOR Cellular Phone
Unlocking the menu button on my tv
you just need a universal remote to program to your tv and remove the lock you can purchase one at walmart
Dec 12, 2008 | LG DU-27FB32C TV
Program ignition key to central locking on porsche 996 1998
Well, you can sometime catch the code again. Pt the key in the ignition and turn till the dash light come on (dont Start) then press and the Lock button while keeping the Lock button Pressed and turn the dash light off and put the key with the lock button Press for 10 second afterwards. If not successful first time try again. This should do it.
Oct 23, 2008 | 1998 Porsche 911 Carrera
My Tv says Keys locked
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
Nov 11, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
2,805 people viewed this question
Top Televison & Video Experts
Electro Med Services...
