Question about Garden
No pressure Gas powered pump is a radial type from DeVilbiss. There is very low pressure, although there is some pulsing from the pumping action. There are no leaks and the supply pressure is good. Pump pistons are in good condition. They seem to be pumping when I had it disassembled and operated by hand. I suspect it is something in the bypass or unloader. Or it may be in the ''easy start'' assembly which I assume reduces backpressure on the pump when starting the engine. Pump has a temperature relief valve but it is working fine. Do you have any suggestions what to check and how to check?
5 Suggested Answers
SOURCE: Pressure Washer Pump and Engine Stops Suddenly
The pump might be binding against the motor, causing the pump to overheat and temporarilly "seize up" and shut the engine off.
After cooling down for a brief period (5~10 mins) the engine can usually be re-started, but the overheating problem will keep coming back.
This happens when the pump either wasn't seated against the engine properly during it's initial instalation, or the pump housing wasn't machined properly and the PTO shaft is trying to drive the pump at a slight angle = excessive friction = overheating.
Try this:
1) Loosen the bolts that mount the pump to the engine just enough so that the pump can be wiggled slightly.
2) With the engine power switch in the "OFF" position, slowly pull the recoil starter rope so that the engine / pump completes about two revolutions. This helps to align the pump surface with the engine.
3) Lightly snug the pump mounting bolts in a criss-cross pattern, then slowly pull the recoil starter rope again to ensure that the pump isn't binding.
4) Finish tightening the pump mounting bolts in the criss-cross pattern (approx. 21 foot pounds torque).
The entire process should take you roughly about 10 mins from start to finish.
If this doesn't remedy your problem, then try running the engine for 20 mins with the pump COMPLETELY removed so as to isolate the components.
Posted on Sep 01, 2009
  • 1388 Answers
SOURCE: Low Pressure
I worked at a tool rental while attending college and had the opportunity to work on a variety of pressure washers, however, they were of the commercial type. Commercial washers are slightly different in that they usually have seperated components for easier service. Attached to the pump by fittings or rubber hose were the pressure regulator (which has the bypass unloader inside), chemical injector, pressure gauge as well as the hot water release safety all external to pump. Your pump has all these components in one case. By far the most troublesome component is the pressure regulator/unloader which when failing will result in low pressure because it will bypass water back into the intake as you suspect is happening to yours. Here are a few things to check. I believe that your pump is 2500 2.4 gpm. Test gpm water capacity by running pump normally with hose and proper tip attached. Spray water into bucket for one minute and verify that you are pumping 2.4 gallons of water (or what ever gpm your machine is rated). Measure the amount of water that your machine delivered. If it delivered proper gpm and pressure is low then problem could be worn or improper tip. The pressure is created at the tip and pressure will drop as the tip wears. As the unloader/bypass wears, water will bypass at a lower pressure. (Try lowering the pressure regulator all the way ) If water measures less than rated delivery than the machine is bypassing water due to worn regulator/bypass, checkvalves pitted, oring in front of checkvalve worn or cut or missing, or body of pump where checkvalve/oring seat is pitted allowing water to leak past valve. The cap that is removed to access checkvalve must presses against checkvalve with enough force to prevent water from leaking thru oring and body of pump. Examine checkvalves and orings with maginfy lens and look for pitting. Valves surface and orings must be very smooth and tight fitting to work properly. Body of pump where checkvalve oring snuggs against must be very smooth. Any surface where oring seats must be smooth. As water bypasses it cuts metal and orings just like a leaking faucet so look for cuts in metal and rubber. This info and my experience is better suited for larger pumps and higher pressure but maybe it will help. Good luck with your repair.
Posted on Jul 11, 2010
wmpcs
  • 100 Answers
SOURCE: I have a 4,000 psi, 4.5 gpm 45G cat pump powered
I would just purchase a new unloader valve, they usually aren't worth rebuilding. I would like to have a picture of the set up that you have, if you can send me a picture of the unloader region of the pump I can get you are price on a new one. email is justin@wmpcs.com
Posted on Oct 25, 2010
  • 969 Answers
SOURCE: Low pressure; as if the
VANES MAYBE CLOGGED, TRY SPRAYING IT WITH PB BLASTER IN THE WATER INLET TUBE & LET SOAK 15-20MINUTES.
Posted on Nov 08, 2010
What causes o low injector pulse
Is that static pressure with key on, engine off? Or engine running pressure? Both should be near 60, usually key on, engine off pressure will be about 3 or 4 psi higher.
If it runs good after starting, the injector pulse must be good. No reason why starting and running pulse should be different. Only difference is when running, fuel pump power is kept on by the oil pressure switch, whereas in starting, the fuel pump relay keeps the pump on. Very unusual, let us know. Measure voltage at one of the injector's power wire with key on. It should be battery voltage or very close.
Aug 22, 2015 | Cars & Trucks
The low pressure soap dispenser doesn't work. I have removed the pump manifold and it is full of rust. I do I remove the injector nipple from the pump manifold to clean it?
To properly fix this you will need to disassemble the hose and fittings, Clean them throughly and replace the hose. Also I suggest that the fatory filter be replaced or a small screen is placed over the line again.
Many of these filters are renoved because they don't fit into soap bottles.
Oct 18, 2013 | DeVilbiss Pk17374 Pump For Excell...
Motor runs but no water pumps through
It's possible that the 'unloader' in the pump is plugged. A local small engine repair shop can replace it (generally under 50 bucks). Of coarse you have the hose hooked up to it and the water on.
Mar 19, 2013 | Devilbliss DeVILBISS Devap DVH2600...
My excell 2600 has no pressure. how can i fix it.
take the pump apart and free up the sticking internal valves
May 21, 2012 | Devilbliss DeVILBISS Devap DVH2600...
Motor turns over but seems to be a lot of pressure on it . it kicks back hard
Make sure you are holding the trigger and water is spraying while you are trying to start it, otherwise pressure will build up in the pump and it will kick back.
Jun 06, 2011 | Devilbliss DeVILBISS Devap DVH2600...
I have got a Devap dvh2600 pressure washer. It has started leaking water badly from inside the pump casing. Can the pump be dismantled? Otherwise I may be able to get a complete new pump unit
yes pump can be taken apart but when you do it will be to your best interest to rebuild with new valves and o rings. Be sure to check the housing and make sure it isn't cracked. If it is cracked throw it away and get a new pump.
May 07, 2011 | Devilbliss DeVILBISS Devap DVH2600...
What type of oil goes into the pressure washer pump...3600psi
I would recommend pump oil for this particular application because it contains special components in the oil but you can substitute as I have done many times with hydraulic fluid.You need to change your pump oil every 50 hours.
Oct 15, 2010 | DeVilbiss Garden
Does the gas tank need to be high on the motor or can it **** from a lower source?
Your water pump is gravity feed type, however you can add a vacuum/pressure pulse type pump. Look here : http://www.motorcycle-superstore.com/4/22/423/22375/ITEM/Mikuni-Pulse-Fuel-Pump.aspx
This is just an example, there are many styles and capacities of pulse pump. Look on ebay. You will need to be creative and find an way to tap into the crankcase system. Some engines that use pulse pump will get vacuum / pressure from the valve cover area. The pump works with the natural pressure / vacuum created in the crankcase by piston movement. Good luck
Oct 07, 2010 | Briggs and Stratton 073001 2" Portable Gas...
I have a DeVilbiss pressure washer, Serial# 2251136878, Model# WVRH2421, Radial Pump# D28703, with a 5.5hp honda motor. It has no pressure. If the pump can't be fixed, is there another brand of pump that...
THE PUMP FITS THE MOTOR and the pump i always use is a ROYALPUMP made in Italy and they are long lasting and easily serviced ,any of the Italian pumps are good
Sep 10, 2009 | Garden
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
