Question about Kenmore 24032\24036 Top Load Washer
Slow water run for cold water
I am having trouble getting the cold water to runin my washer as fast as my warm and hot water. What could possibly be the problem?
Slow water run could be caused by the filter on the cold water hose is clogged by granite or mineral deposits
1. turn off the water to the cold hose
2. drain water out of hose and detach from washer
3. get a water spray bottle and set to strong stream not spray,
spray the filter that goes into the machine, this should clean out the debris that is clogging the line hold a small container to catch water when you spray if you see black specks it granite
4. after it runs clear reattach hose and turn the cold water back on that should solve your problem, it did the trick for me
Posted on Dec 23, 2007
Kenmore 70 series washer
If you can see a constant water pressure from the hot and cold, chances are the water solenoid valves are ok.
I would look towards resetting to factory and checking the main control unit.
May 11, 2014 | Washing Machines
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Hot water
new washer valve on washers are designed to be "energy saving" most are 70/30..on warm 70 percent cold and 30 percent hot also new temp controls will reduce temp to a "safe level" by adding cold even on hot setting the on/off of water flow is being controlled by thermal sensor in water line on valve output ..in other words it's normal
Jun 09, 2008 | Crosley CAWC529JQ Top Load Washer
Very slow cold water flow
soundslike either your cold water supply is not turned on all the way or the inlet valve is clogged w/debris. try removing cold water hose and checkin inside the valve, sometimed youll be able to remove sediment adn debris from valve from screen, if thats not the case youll need to replace the vavle itself
Apr 17, 2008 | Maytag MAV2755A Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Roper washer: Slow fill on hot setting
You can really thank the government for this- your washer has a 75/25 split valve (75 cold 25 hot--- so warm is mostly cold) which they mandated for all standard top load machines. In 2010 they are banning manufacting of all standard top loaders. The thermistor is because your machine has a ATC (automatic temperature control) system. It has a computer which monitors water temp for better laundry care. You could possibly have a repairman (this wouldnt be covered under warrany) try to retrofit a older service valve in your machine.
Jan 13, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
106 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
