Question about Amana Ovens
F2 on my gas oven
F 2 on my gas oven
  • 6,784 Answers
HI, This is a oven temp sensor failure code. The actual sensor should be replaced asap. This will correct the issue.
F-2(Oven Temp Sensor failure)
Posted on Oct 03, 2009
F-2 error on digital screen, mAYTAG GAS OVEN, SELF CLEANING not sure model #.
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 31, 2011 | Maytag CWG3100AAE Gas Oven
F2 flashes and beeps. What does it mean?
F2 usually means that for an unknown reason, the oven temperature has exceeded a preset threshold.
Check the sensor bulb in your oven, it could be bad or your thermostat is not working properly.
Jun 19, 2011 | Magic Chef 9112 Gas Double Oven
OVEN TURNING OFF BY ITSELF. I THINK THE CODE ON IT IS SAYING F2
Hi!
The F2 code means Oven Temperature Too High. When this code is present do the following:
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Nov 02, 2010 | Whirlpool SB160PEE Gas Single Oven
Oven pre heats then beeps with "F 2"
Hello,If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board.
If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically.
Thanks
May 28, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Blinking EO and F2
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jun 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore gas oven
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Apr 22, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
F2 Beeping!!!!
F2 Oven too hot Replace oven temperature sensor
Mar 09, 2008 | Kenmore 33464 / 33465 / 33469 Gas Single...
Error message on Whirlpool Gold gastop range: E0 -F2-
It means "shorted keypad".
1. Disconnect power from oven for longer than 30 seconds.
2. Re-apply power and observe for longer than 5 minutes.
3. If failure remains, disconnect power, replace control, then
go back to step 2.
4. Unplug and replug membrane connector.
Dec 29, 2007 | Whirlpool SB160PEE Gas Single Oven
F2 error code
Intermittents are a real problem. My first guess: look around for a corroded or damaged electrical feed. Could be electrical noise from that. Not sure what No other possiblities other than a bad panel. I don't know what F2 is.
Dec 06, 2007 | GE JGRS14 Gas Single Oven
Ovens Logo
67 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
