Skipping typewriter. I've only recently had problems with the typewriter in my office. It seems like some letters print fine and others are barely visible. I replaced the ribbon a few days ago thinking that would fix it, what do I do now?
  • 1 more comment
  • OneTimeOnly Dec 26, 2007
    It's an Adler Royal Satellite 4...I think, at least that is what it says on the front of it.
  • OneTimeOnly Dec 27, 2007
    The bumper on this one is metal and plastic. The letters and the part that hits them is all plastic. Could it be the actual plastic letter things are getting worn out? How would I fix that?
  • OneTimeOnly Dec 31, 2007
    Thank you!
  • 478 Answers
What brand typewriter do you have trouble with I may be able to help.
Posted on Dec 23, 2007
  • 1 more comment
  • James Cagle
    James Cagle Dec 27, 2007
    There is a round rubber bumper on the hammer mechanism that gets mushy and if it is it will have to be replaced.
  • James Cagle
    James Cagle Dec 31, 2007
    It could be a worn type wheel if the same letters always look the same but if they sometimes look good and sometimes look bad it is either the ribbon or the hammer drive solinoid see my comment above.
  • James Cagle
    James Cagle Jan 04, 2008
    Sme of the adlers had nakajima printers in them if it a nakajima printer the hammer driver located on the right side of the carrier had a tendency to crack at the mounting hole if so it will need to be replaced. I do them in my shop for $54.56 inc parts and service of the machine.
I've changed the batteries and the typewriter won't print. It looks like the keys are not coming up to print the letter. I thought I properly installled the ribbon but it seems as though the ribbon...
Most likely the plastic print solenoid cap is broken. We sell them fo 20.00 includes instructions & shipping.
DickyO
Cleveland Business Machines
216-241-0027
May 18, 2011 | IBM Wheelwriter 30 Typewriter
My Dad has a Royal TA memory typewriter. He tells me it is typing every other letter. It's not double spacing his letters..it's skipping every other letter. He also says it's making a clickity clack...
It sounds like the ribbon is twisted and interfearing with the P/W Try installing a new ribbon and check the P/W for bent or broken spokes.
DickyO
Mar 11, 2011 | Royal PowerWriter Typewriter
Swintec 7000 Typing Problem
Try Code comma, peroid or slash one of them will get you out of the overstrike ribbon mode.
DickyO
Jul 08, 2009 | Swintec 7040 Typewriter
Only a portion of the letters are printing on the paper.
Sounds like the platen has worked loose. press down firmly on both ends of the platen (black rubber rol) it should snap back into place.
DckyO
Jul 02, 2009 | Lexmark Wheelwriter 3000 Typewriter
Letters and numbers not printing correctly
It sounds like you have a damaged printwheel. Get a new one and try it.
DickyO
Apr 28, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 3500
First look inside the typewriter for forgien objects and debris, Then put some libhe oil (WD40 works well) on the shaft that the print head slides on.
DickyO
Oct 09, 2008 | IBM Wheelwriter 30 Typewriter
Getting Tired
Look at the ribbon. Is there a space for each letter? If so see if you can get some WD40 on the back and front of the print solenoid plunger. The solenoid is located below the ribbon just inside the l. printer side frame it dose gum up. if the ribbon isn't moving try anew ribbon and WD40 on the ribbon motor top and bottom bearings.
DickyO
Jun 10, 2008 | Lexmark Wheelwriter 1000 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
150 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
