Question about Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual
Treadmill makes a high pitch whirring sound that varies with the speed. Sounds like it comes from the motor compartment
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
Engine makes high pitch sound
sounds like a vacuum leak check for cracked vacuum lines
Sep 03, 2013 | 2003 BMW 325
My Epic 425 is getting louder and louder, a whirring noise, but can't seem to find maintenance help
It sounds like you have a drive motoer failing. The only other place that can be load or making noise is the front and rear roller. The rollers bearings when failing make a "popping" or "clicking" noise, and increases as you speen up. The motor "growls", and the faster you go the noise is..... well loud. The way to confirm this is to remove the motor hood, then start the treadmill on power/speed level 3. Be very carefull, and use a broom stick (wooden) to put on the drive motor while it is running. You should be able to "feel" what you are hearing. You should then raise the speed, and you will then feel the increase as well.
The replacement motor is around $200.00.
Hope this helps
Nov 12, 2010 | Epic 425 Mx Treadmill EPTL88105 !
My 2000 Explorer makes a whirring sound when you accelerate - can this noise be due to a bent tierod? The previous owner had an accident involving the front end and was told that the tierod was haywire?
Typcially tie rods will only make a clunking noise or a squeak. The whirring sound if would suspect to be a wheel bearing. When you drive, slowly turn from left to right, if the pitch changes than its the bearing.
Mar 28, 2010 | 2000 Ford Explorer
EXP 1000 starts and stops after about 7 minutes. Irregular speed changes during work out speeding up and then stopping. Thanks, Bill Hutton
I am not familiar with this model but it sounds like a speed sensor error.
Try un plugging treadmill, removing front cover and cleaning motor compartment paying special attention to motor and fly wheel. If that does not fix it may be a problem with speed sensor or circuit board.
Feb 07, 2010 | Nautilus Exercise & Fitness
The motor is making a whirring noise a bit of a smell coming out (burnt type smell)
Sounds like either the drive belt is slipping or your motor is going bad. If you see fine rubber dust on the floor or machine hood area it's the belt.
Jan 25, 2010 | Exercise & Fitness
HI I have a 2 1/2 yrs old Samsung 48'' DLP. just recently it has developed a whirring noise it appears to come from the rear of the TV and to me a(a layman) it sounds like a fan, every time I shut it down...
sounds like bushing worn out in fan motor solution replace fan fan important it increase the life of lamp sugg mouser electronics.com shoulid have part 4 around 60.00 bucks
Jul 25, 2009 | Samsung Televison & Video
Same humming/whirring sound from freezer
sounds like the evaporator fan motor is on its last legs. that is the part i would check.
Sep 25, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual Logo
268 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Paul Sikkema
Paul Sikkema
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
