Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
My computer hp m705 pavilion crt monitor always has the osd continuously displayed... i want to get rid of it...... the control buttons are not working as well... pls give some suggestions
Me too having same trouble..All HP m705 series makes trouble like this..Hp Customer care told that to repair the front panel buttons.It's the only way they told
Posted on Oct 11, 2009
  • swap
    swap Oct 12, 2013
    what is the cost for repair please reply..
If you are able to replace the front pannel switch , otherwise call service enggr.
Posted on Nov 25, 2009
This osd lockout pops up quiet often on my screen what can it mean?
Try this
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"....if the problem continues. Switch of the monitor and remove the power cable and connect it again.
Mar 25, 2010 | HP Pavilion dv6000z Notebook
Osd lock?
Depending on your monitor:
Solution 1
1. Disconnect power cord.
2. Press and Hold button 1.
3. Plug power cord back in.
4. If necessary, press power button while still holding button 1.
Solution 2
OSD and Power Button Lock Modes
OSD Lock This mode locks all current control settings and prevents access to
the control menus until this mode is unlocked.
? OSD Lock: Press and hold [1] and the up arrow  for 10 seconds. If any
buttons are pressed the message OSD Locked will display for 5 seconds.
? OSD Unlock: Press and hold [1] and the up arrow  again for 10 seconds.
See page 7 of this User Guide for further instructions:
http://www.viewsonic.com.au/support/manuals/files/LCD/Series%20X/VX715-2%20User%20Guide%20English.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
OSD lock should now be cleared.
Feb 04, 2010 | ViewSonic E70f (White) 17 in.CRT...
OSD LOCK
Normally the OSD lock will only be displayed for 5 seconds.
Regardless you should be able to get rid of it by pressing holding the up arrow key for 10 seconds.
If this fails to resolve the issue try this. Disconnect power cord. Now press and hold button 1. Plug the power cord back in. You may have to press the power button while still holding button 1. The OSD lock should clear after that.
Hope this helps.
Oct 02, 2009 | ViewSonic E70f 17" CRT Monitor
The osd main menu has appeared on my hp pavilion f1703 monitor
Control Panel->System->Hardware->Device Manager->Monitor. select and uninstall. Then let Windows detect the monitor and re-install the drivers for your monitor. Do the same for the disply adapter in the Ctrl Panel.
Aug 24, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
OSD automatically displays and I can't rid of it. Monitor display adjustments are being made and I can't control it. Sometimes it's like this. Sometimes it's OK. I am having this problem for months...
My view sonic monitor E70fB Model. Without I Press the menu, it always appearing on the Screen. Some times Contrast up/down and osd lock and it suddenly scrollsfor other options.
If I press the exit button, it sometimes exits or agin it occurs.
So please kindly solve this problem
Dec 06, 2008 | ViewSonic 17" CRT Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Whereabouts and meaning of OSD
OSD stands for On Screen Display. You get to it by pressing the Menu button on the front of your monitor.
Here's a link to making adjustments...and unlocking the OSD:
HP f1703
Oct 18, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Osd lock
Dear srinivasvodn,
Press the menu button of your monitor for a wile OSD lock will unlock.
Aug 05, 2008 | ViewSonic 17" CRT Monitor
Hp pavilion f1503 momitor
Hold the MENU button for 10 seconds to lock or unlock the OSD
Aug 05, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
The osd menu on my moniter
i have the same probelm on my HP PAVILION F1503..
its really annoying. were u able to fix this problem?
thanx
Sep 11, 2007 | X-10 17 in. CRT Monitor with OSD Controls
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
237 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
