I need a replacement fan for my window unit - Heating & Cooling
  • Josh White May 11, 2010
    Not enough information. Make, Model, Serial Numbers needed.
    We need make and model numbers to be able to assist you.
  • 45 Answers
Ring the manufactor how made it and its a bit dear to buy them.thay can rang in price from 150 to 450 dollars mark.just get a new one.its cheaper
Posted on Oct 04, 2009
Sometimes get a loud screeching noise from the condenser fan motor. Also seems to be loudr than usual. Motor part no. is:S070. Can a "do it yourself" guy replace the unit?
If this is wall/window unit, you can do it but it can be tricky. the fan in window units usually has 2
shafts on either side , it drives fan for both the condenser and evaporator. You basically have to pull the top off, loosen set screw on both blades, remove some screws to move back condenser coil(gently, don't kink tubing) similar process on evap side. Then mount new fan motor, wire it in put fan blades back on in proper position, reassemble unit, test run on bench.
Jun 26, 2011 | Heating & Cooling
How do I change out the fan motor on my LG LWHD1200HR AC/Heat unit., as it needs to be replaced, Im a technician on major appliances, but have never replaced a fan motor on a window air conditioner. any...
Unplug the unit and remove it from the window. Place it on a secure surface for working on it. Take off the cabinet. Remove the fan blades and disconnect the wires at their terminations. unbolt the motor and bring it, along with the make, model number and serial number, to the nearest United Refrigeration or W.W. Graingers. Have the counterman match it up for you. Reverse the above procedures, remembering to replace the capacitor.
Jul 18, 2010 | LG Heat cool Window Air Conditioner
Loud fan noise
replace the fan or replace the unit
Jul 12, 2010 | Heating & Cooling
I have a carrier window unit that lost a fan blade
you can by a fan blade. any refgriation parts store can get you one or you can get the model number and order one off the internet.
Jun 30, 2010 | Carrier BCA101R Air Conditioner
It is very loud inside when turned on. the noise sounds like a loud rumbleling noise.
Is this a window unit, a whole house AC, or a Split package type?
If it is a window unit remove the front cover, reach in and see if the blower fan teeters on the mother shaft. If it does the blower fan center hub has failed and the fan will need replaced. (I have changed 2 blower fans on my Carrier 19,800BTU window units that run 23 hours a day.) They just fail over time. Who knows why.
Kelly
Feb 23, 2010 | Heating & Cooling
My fan is not working....just hums.
Getting into window unit is tricky. The motors go out quite often. Might be capacitor. But you have weigh wether it cost more to fix than replace. Rus
Jun 14, 2009 | Whirlpool ACQ158XP Wall/Window Air...
I have a loud knocking noise coming from my window unit a/c. What could be the problem?
This could be the evaporator/condenser fan blades striking the housing or it could be the compressor.
Turn the unit to "fan only" and see if it makes the sound you describe. If so, there is an issue with the fan. You may need to remove the outer cover and see why the fan is making noise. Look for debris, or insect nests that may have taken up residence. If no obstructions, look for bent, cracked or broken blades and possibly loose blades. Make sure the A/C unit is unplugged before working on it.
If no noise in the fan mode, turn the selector switch to cool, being sure that the thermostat is set low enough for the unit to try and cool. If the sound is emanating from the compressor, there isn't much that can be done in terms of repair and it may be time to replace the A/C unit. Compressors aren't usually worth the cost of repairs.
Apr 30, 2009 | Kenmore 76100 Wall/Window Air Conditioner
Power on unit hums but does nothing else just keeps humming?
hi there,
stuck up motor,could be capacitor check this out and replace.
could be relay.if defective replace.the motor has star winding after replacing capacitor and humming again,check start winding,if high resistance,replace motor.have a good day,rate me if your satified to my suggestion,thank's a lot
Apr 28, 2009 | Whirlpool ACQ158XP Wall/Window Air...
Broken barrel fan
I am not familiar with the Blueway brand but have never seen an air conditioner on which you could not replace the fan.
Is this a split system or a window unit? If a window unit it may not be worth the trouble.
Jan 29, 2009 | Heating & Cooling
Whirlpool A/C Model #ACQ158XP
Unfortunately, your model does not have a fan belt so you may need to have it serviced by a technician. Prior to calling one, clean the room air filter and hose off the coil from the outside if you can get to it. Unplug the unit first. The squealing may be a dry bearing in the room air fan. If you can get to the fan, put 2 or 3 drops of electric motor oil on the fan shaft and work it into the motor housing by hand. Make sure you are getting power at the outlet. If so and the unit does not show any signs of life (lights or a fan), probably the fuse inside the unit has blown and will need replacing. Good Luck.
Sep 26, 2007 | Heating & Cooling
Heating & Cooling Logo
21 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
