Question about Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Sprayer arm My top sprayer arm has come off. How do I re-install it?
The arm simply attaches to the underside of the basket. slide the front of the arm over the round bar on the underside of the basket then clip the arm over the round bar on the back of the basket
Posted on Aug 24, 2008
The top sprayer holes on sprayer arm are blocked, how does sprayer arm come apart to clear blockage?
The sprayer arm does not come apart. You have to remove the sprayer arm and use an object that fits in the holes to clear the blockage.
May 28, 2012 | Kenmore Dishwashers
My dishwasher does not clean my dishes good
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Usually in the center of the spray arm is a wing nut. Simply unscrew this to remove the arm(s). Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 05, 2010 | Kenmore Dishwashers
Arms are clogged
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
Dec 04, 2010 | GE Dishwashers
Spray arms blocked how do I detach clear/clean them?
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. In the center of the sprayer arm there is usually a wing nut that unscrews easily and releases the sprayer arm. Once you have removed the arms, rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
Dec 04, 2010 | Bosch Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The top section wont wash clean
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water does not spray or circulate
Dec 02, 2010 | Asko D1776 Stainless Steel Built-in...
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher fills up, but doesn't spray.
Dec 02, 2010 | Dishwashers
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher Logo
75 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
