Question about Dell 926 All-In-One InkJet Printer
Dell 926 paper feeder does not work
When it tries to load the paper it takes one side more than other and then doesn't continue through the caridge ends up jamming everytime.
futureloginn
  • 734 Answers
SOURCE: Paper Jam feeder
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
  • 5 Answers
SOURCE: Dell 1720dn takes extra blank page at end of job and jams
There are rubber rollers that grab the paper to pull it through typically these get slick over time and will cause the printer to grab an extra sheet of paper. How I usually fix this problem is to check and see if the rollers are slick if so then I take an Emory board to them to rough them up just a little bit. I have also in the past used clear finger nail polish on the roller and that has helped. I would apply a bit of the clear polish to the roller, if it did not work then I would take the Emory board to it.
Posted on Feb 20, 2009
virtualhost
  • 2185 Answers
SOURCE: Dell 1815dn feeder jam. What will fix this
Look inside for paper jams stuck between ng rollers.
Also, rollers might be disaligned so you need to check them as well.
Posted on Aug 01, 2009
SOURCE: dell 926 photo printer will not print black ink.
I'm am having the exact same problem with a new Dell 926!
Posted on Feb 16, 2010
pineworks
  • 4041 Answers
SOURCE: paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Printer will not feed paper correctly. It only goes so and then bunches up and stops. There does not appear to be any paper jam.
First and foremost, call Dell to make sure that your printer is not still under warranty. If it is out of warranty, then follow steps below:
A: What is happening is the feeder is either clogged with something blocking the path or one of the prongs which grab the paper is broken/faulty. If you are unable to to open the printer and get to the roller to change the feeder, then you will need to go to a local repair shop to fix the issue.
B: If you are able to get to the roller to change the feeder, then you can easily order the part from Dell.
Dec 07, 2010 | Dell 926 All-In-One InkJet Printer
I have a dell 926 series printer lost the booklet how do i load the paper
You posting shows a Dell 3100cn printer (laser), but you say it's a 926 (inkjet). If a 3100, pull the bottom paper cassette tray out and load the paper. Make sure the sttigs for the paper are correct, e.g. "Letter". If it's a 926, the paper goes in vertically at the top rear of the printer.
Apr 25, 2010 | Dell 3100cn Laser Printer
Have 926 All-In-One. Paper jams as it enters printer. No apparent obstructions. Used new single sheet of paper. Any way to get into the unit to check further? I work as a tech and am comfortable...
hi :
possible u have a carrier jam which cause the paper to skew.
-open the front cover and check if the cart is struck @ a corner
---if so then gently pull it over to the centre .and restart the printer ,
--also check from any broken strip inside the printer
--see if u can find the roller inside the feeder tray to be at the centre ,
-make sure the papers u use dont have dog ears .
if u printer is in warranty call 8006249896 and get a replacment from dell .
hav a gooday !
Jul 30, 2009 | Dell 926 All-In-One InkJet Printer
Envelope stuck inside of printer Dell Photo AIO Printer 926. Can see it down inside from the loading side but no where else and it won't print anything else (won't load the paper). How do I get to the...
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page
Please rate this solution if you find it helpful!
~~Cheryl
Dec 22, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 all-one inkjet printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
Oct 24, 2008 | Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Paper problems
I had same problem. first turn of the printer and unplug electrical supply. turn the printer upside down and make sure there is nothing stuck in paper feeder. the next step, take a paper sort of a greetings card and try to run it through the feeder gently. if you cant get it through then don't force it. but this will clear up any object stuck in to paper feeder. now plug in yor power cord and try a test page from your printers properties. hope this will work for you. good luck...........
Aug 16, 2006 | Dell 810 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
105 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
