Question about Bernina Artista 180
180E Hoop problem
I have a 180E and I switched embroidery designs from a medium hoop to a design that needed a large hoop. The machine doesn't recognize that I have a large hoop on. It thinks there is a small hoop and I keep getting the error message to " change to a larger hoop" I've tried everything I can think of to try to get it to do a bigger design, but I keep getting the same error message.
Please help..
Thanks.. Joan
  • Roush345 Jan 22, 2008
    Same issue with custom designs
  • judymom59 Dec 19, 2008
    I just finished a design on the large hoop, rehooped for the next design on the large hoop and it is no longer reading the large hoop. Also telling me to use a smaller hoop. Very frustrating especially since I am trying to finish these projects for Christmas.
    New Friend:
  • 185 Answers
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Posted on Feb 25, 2008
I have a Viking designer ruby machine. I am trying to embroider a name. I have the right hoop and the design fits the hoop and I keep getting an error message.
Sometimes machines will not work because even though the hoop appears large enough, there is not enough leeway for the presser foot to maneuver inside the hoop. This is a common issue with embroidery machines. The probably answer is to either shrink the design or use a larger hoop.
Nov 13, 2016 | Sewing Machines
When I install embroidery hoop light keeps blinking n saying wrong hoop size looked it up n it's saying malfunction
Ok, there are a couple of possibilities, and I'm going to include an image. I"m not sure whether you're trying to use the small or large hoop, but the first thing you should try is turn off the machine, take the hoop off entirely, then turn on the machine without anything and let it reset to its default position, which will be the center. If it has a problem there, make sure the needle it at its highest position.
Next, put the large hoop on, bring up a design, (preferably a design that came with your machine--there are sample designs in the \Library directory where the program is--that's generally in c:\program files\futuraquartet--and is designed for the hoop you're trying to use, and transmit to machine. If it tells you the hoop is the wrong size, download a patch from If it STILL tells you you have the wrong size, reseat your USB cable into the machine and tape it in place with masking or duct tape.
The third possibility--and the one pictured in the photo I'm going to attach--is there is a tab on your hoop which indicates the hoop size, and your TAB may be off. It needs to be dead center of the sensor, which is also pictured. A while ago a BUNCH of hoops were manufactured with the tabs slightly off, and if it's off, your machine can't read the size. What generally happens there, though, is it will indicate that there is NO hoop attached, rather than the wrong size.
You can see the sensors--they're inside the arm where you put your hoop, and they're not covered up. Below it are the large hoop (top), and small hoop (bottom). The hoop tabs have to match up to the sensors exactly, and you'll be able to see if it doesn't by matching up the notch in the hoop that matches the catch in the embroidery arm.
Oct 20, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
When you are editing the design make sure you are actually doing it in the hoop size that you want. It may be that the design has been done in a larger hoop although it does not really require it. I can change the hoop size on my machine. Good Luck!
Oct 15, 2017 | Bernina Sewing Machines
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Bernina artista hoop not recognized
Calibrate the embroidery hoop
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I have a Do All Quilter's Hoop which I can't use
I'm a bit amazed that a Husqvarna technician was unable to do the minor adjustment to the embroidery arm - he needs to contact Husqvarna headquarters and ask for instructions. Meantime, you can still use your hoop (which by the way is my favourite hoop - it's a little beauty!). Tell your machine you are going to use the Large Hoop (6" x 9.5" or 150mm x 240mm) even though you are really using the 6" x 6" or 150mm x 150mm Do It All Hoop. Provided you have centred your design before loading it on your USb stick or floppy drive, it should work. However, just to reassure yourself, use the Check Size button on your touch screen to test the outside size of the embroidery and be sure it is not going to foul on the hoop borders. (It is the one on the second screen (press More to access this) once your have loaded your design - looks like little double arrows pointing to the corners of a square. Each time you press this button, the needle will zoom to each outer corner of your design in turn.
Jul 10, 2010 | Husqvarna Designer I
I have the quilters 150x150 hoop and I need an update to use it, the button on my embroidery machine is grey I think it needs to be dark blue
Dark grey, actually, but you don't need the upgrade. Set the hoop size at the machine for the 150 x 240 hoop and the 150 x 150 hoop will work. Just be sure that the design starts in the centre i.e. don't move it up or down at the machine Embroidery screen. Before you begin sewing, check that the design will fit in the hoop without bumping the sides of the hoop. Use the Check Size button which is on the second screen of the Embroidery Screen (touch More on bottom right of first screen). The Check Size button is the one on the bottom right - the first button to the left of "More". Touch it once, hoop moves to top left of design; touch again hoop moves to bottom left of design; again hoop moves to bottom right; again hoop moves to top right.
Make yourself a note so that when you next take your D1 in for its regular service, get the hoop upgrade done at the same time. You need to have at least version 2.1 of the machine software installed - your tech. can do this for you too. It is a really minor adjustment so should not add much to the service cost. Be sure to take the embroidery unit in too when you go for the service.
Nov 16, 2009 | Husqvarna Designer I
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
Sewing Machines Logo
266 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
