Question about Sony Video Cameras
The tape runs for 3 seconds then error message ''please re-insert cassette / on screen error code C:32:22 - head cleaner tape has the same effect
When I got this error I removed the battery for 10 seconds and then put it back in. Camera should come on automatically. I just did this to mine and it seems to work.
Posted on Aug 13, 2010
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
Cassett does not get inserted
Put a head cleaner tape in camera and run it for 20 seconds ever few months.
May 29, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
DCR-TRV285E PAL C:31:23
It is telling you it does not see a proper type tape in the camera, is the cleaner tape a digital 8 cleaner or normal 8? as though they look the same the case is slightly dif at the rear.
May 22, 2010 | Sony DCR-TRV285E Digital-8 Digital...
2001 Tahoe cassette tape cleaning
I think you need to remove the unit and have it repaired, it is faulty.
Jun 07, 2017 | 2001 Chevrolet Tahoe
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
Bands or lines on screen during playback
Hi tlaufer ,
              According to the symptom this problem is related to the VIDEO HEAD, As you earlier try to clean the head but no results, Please open the cassette compartment of your camera (as when you insert the cassette in it) for 30 mins (remains open cassette compartment) Actueally some time due to moisture head get durt.
After 30 mins insert the cassette and play it. Hope it will start work again fine.
      But if no result from the said procedure then there must be a damadge of point of the head, in this condition you have to replace the VIDEO HEAD assembly.
May 23, 2009 | JVC GR-D73E Mini DV Digital Camcorder
HDR-HC1 Sony camcorder- reinsert the cassette error message
Bill,
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
Mar 07, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
MX2, it displays the following: "remove the cassette" or eject. I thought it was a condensation problem but all attempts failed, please help me.
On Canon camcorders, "remove the tape" error is due to no data reading by video head. You may have clogged heads or somewhere along the area. Initially, I would try to insert good clean "video head cleaning tape" and run for about 7 seconds and see if that resolve the symptom. If it persists, it need a help from a technician. Good Luck. For further help, go to www.camerarepairjapan.com James
Feb 26, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
Reinsert cassette
Turn the unit off and hit the back of the camera twice near the battery compartment with the palm of your hand. Sounds crazy but it worked with my camcorder Sony DCR-TRV480. Problem started when I used 8MM Head Cleaner. I think the roller got stuck inside camcorder. The trouble code came up C:31:22. Hope this helps.
Feb 13, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Jun 18, 2007 | Sony Handycam CCD-TRV107E Camcorder
Video Cameras Logo
107 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
