Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Kenmore 911-4658811 will not set or heat up above 170 degrees
The digital display on the range will not set, or allow the oven to heat above 170. It is currently a great plate warmer, but not an effective oven. Help?
    President:
  • 1,304 Answers
Pull the range out, unplug it, remove the small tin door, ohm out your bake element,
if its gas well then thats your ignitor
Posted on Oct 03, 2009
How to calibrate kenmore meat probe? it says 170degrees when plugged in cool.
170 degrees is likely the minimum it can read. put a container of water in the oven, put the probe in the water, and set the oven for 250 degrees. Watch the probe, and see what temperature it shows when the water boils. Depending on your altitude, it should be 212 or a little less.
Sep 04, 2014 | Kenmore 30 in. Freestanding Induction...
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
Kenmore plt083-2 won't heat above 200 degrees
Please check that model number again. The one you posted comes up as a refrigerator. Look inside the oven door or the lower drawer.
Feb 03, 2014 | Kenmore 91112 / 91114 / 91117 Electric...
Oven temperature in main oven does not reach above 200 degrees. Is this a coil problem or a themostat problem?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 05, 2010 | Kenmore 75503 Stainless Steel Dual Fuel...
Oven won't light on low settings (170), no trace gas smell.
Igniting bar located on the inside of the oven it is a rectangular piece with one or two screws. It is basically a heating element that also controls the gas. Change that ignitor and it should fix it no problem.
May 03, 2009 | Frigidaire FGF326AS Gas Kitchen Range
DON'T REACH TEMPERATURE
it could be either or. i would replace the element first as it's much cheaper.
Aug 26, 2008 | Maytag MER5552BAW / MER5552BAQ /...
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
284 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
